Old 06-05-2018, 09:46 AM   #1
NC_John
NC_John's Avatar
Fittings for IAT Sensor and Vacuum Line?
I tried asking this on LS1tech but I guess I don't know the secret password over there to get any responses. I need to get my IAT sensor and a vacuum line hooked up into the air intake I am piecing together on my LS.
I'm eyeballing this to use for both:
http://www.siliconeintakes.com/holse...er/-p-500.html
I'm hesitant because it says its good up to 3" diameter hose. I am running a 4" (feeding a 102 intake). Has anybody used this on anything larger than 3"? I'm guessing they limit it to 3" dia for sealing issues but wonder how bad it would really be on a 4" silicone section.
Does anyone know of anything else that is available? I guess my other option is to have a couple NPT bungs welded onto an aluminum straight section but that would have to be plan B as I would not be able to weld that myself.
thanks...
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 06-05-2018, 12:57 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Fittings for IAT Sensor and Vacuum Line?
My guess is the profile of the backing tab is radiused for the 3" pipe. A 4" section would be a more subtle curve, and probably leave some of the tab protruding into the intake.
Are you running a MAF that doesn't have IAT built in? You could consider converting to an MAPT.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-05-2018, 02:32 PM   #3
NC_John
NC_John's Avatar
I'm wondering if the manufacturer is just erring on the side of caution as to limiting it to 3". I might order one just to see.
No MAF. I'm running a speed density tune.
thanks
1970 C-10 LWB "Blu"
Old 06-05-2018, 04:28 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
thanks
If your running SD on a Gen III, then you should be able to swap the MAP for a TMAP/MAPT
Old 06-05-2018, 08:59 PM   #5
NC_John
NC_John's Avatar
I am but this late in the game I think it'll just be easier to get the iat figured out. Worst case is I get a couple bung fittings welded into a straight aluminum section of the intake.
Thanks!
1970 C-10 LWB "Blu"
Old 06-05-2018, 09:29 PM   #6
NC_John
NC_John's Avatar
Thanks!
1970 C-10 LWB "Blu"
Old 06-05-2018, 10:16 PM   #7
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
If you did truck may, or ls7 card style mad, it has temp sensor in it...?
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 06-06-2018, 07:49 PM   #8
NC_John
NC_John's Avatar
Whats a mad? Typo?
1970 C-10 LWB "Blu"
Old 06-06-2018, 11:26 PM   #9
dayj1
For the IAT, can't you just use a factory IAT grommet in your intake tube? I'd probably just pull one out of a car at the junkyard. Any of the zillions of FWD early-to-mid 90's GM vehicles should have one. Here's a new one to show what I'm talking about.
https://www.eficonnection.com/home/product/grommet
For the vacuum line, I bought one of these kits at the local parts store a few years back and I've used in on 3 or 4 swaps since then
https://www.amazon.com/Spectre-Perfo.../dp/B000BQ090Y
dayj1 is offline   Reply With Quote
Old 06-06-2018, 11:27 PM   #10
dayj1
Whats a mad?
MAF + autocorrect = mad
Old 06-07-2018, 09:17 AM   #11
NC_John
NC_John's Avatar
No sir... good thought but I have (what I believe is) the ls6/ ls7 type IAT sensor. It's 3/8 NPT.
The vacuum line kit might do the trick though. I think I'll get one on the way and see what I can do with it. From the review it sounds like the hole saws should not be used but everything else is OK.
thanks for the tip!
1970 C-10 LWB "Blu"
Old 06-07-2018, 09:47 AM   #12
NC_John
NC_John's Avatar
No MAF. Running a speed density tune.
1970 C-10 LWB "Blu"
Old 06-07-2018, 10:22 AM   #13
dayj1
If it helps you at all, the GM IAT sensors can be interchanged. In other words, you can use the LS1 push in style if you want. I'm not going to say that all of the GM IAT sensors are the same internally, but most are. And in the odd cases, the calibration is easily changed in the tune as there is a table for resistance vs. temp.
Old 06-07-2018, 10:34 AM   #14
NC_John
NC_John's Avatar
Thanks. The sensor is brand new and everything is set up for it so I'll probably just get a sensor bung welded onto a straight section (probably using aluminum pipe) and be done with it.
1970 C-10 LWB "Blu"
Old 06-07-2018, 12:10 PM   #15
87chevy.com
Whats a mad? Typo?
Oh yeah, typo. Maf*
