Old 06-11-2018, 06:42 PM   #1
greentruck
greentruck's Avatar
Egg off throttle body
What's the best and permanent way to plug this?
For some people driving is one long series of corrections...
greentruck is offline   Reply With Quote
Old 06-11-2018, 06:51 PM   #2
greentruck
greentruck's Avatar
Re: Egg off throttle body
Not egg. I meant egr. Auto correct on my phone gets me in trouble sometimes.
Old 06-12-2018, 12:01 AM   #3
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Rubber caps from auto parts store will dry rot in a few years, simple and cheap. Not sure of any permanent solutions..
Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 06-12-2018, 10:06 AM   #4
greentruck
greentruck's Avatar
Re: Egr off throttle body
That's what I've got on there now. I don't think it will last long.
Old 06-12-2018, 11:55 AM   #5
71cadc10
71cadc10's Avatar
you can tap it for NPT and screw in a small brass plug
it's the EVAP port by the way, pulls fuel vapor from tank.
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
Old 06-16-2018, 11:07 AM   #6
davepl
davepl's Avatar
It shouldn't actually be plugged, should it? If so the engine won't be able to pull fresh air through the crankcase via the PCV system.
I -thought- it was a metered orifice that flowed at a known rate and as long as you provided it with a supply of fresh filtered air, the ECM took account for it in the tune.
No?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-16-2018, 11:00 PM   #7
87chevy.com
No?
I'm sure that's the case when the pcm is turning the solenoid on. When the solenoid is off.... it's not doing anything besides acting like a plug
Old 06-18-2018, 04:06 PM   #8
ls1nova71
ls1nova71's Avatar
No?
The OP is calling it an EGR fitting, and you're thinking PCV. It is neither, its for the evap purge solenoid to hook to for pulling fumes out of the gas tank. Its not needed on a non emmissions friendly swap.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 06-19-2018, 10:15 AM   #9
greentruck
greentruck's Avatar
Thanks for the replies on the EVAP. I ended up using a small piece of hydraulic line with a fitting pressed on it and a threaded cap. I think it will last.
