06-16-2018, 09:49 AM | #1 |
Check The Champ, Demonstrator
WTB single add on water pump pulley SWP
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
06-16-2018, 12:39 PM | #2 |
Re: WTB single add on water pump pulley SWP
Will check my parts stash later today and get back with you. May have one, not sure if sold it at last swap meet. If I have one, will take pics of what I have to be sure we're on the same page.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
06-16-2018, 01:55 PM | #3 |
Well thats my problem .1000's of pages of literature and no picture. Seems to fit over a double groove pulley.
06-16-2018, 02:30 PM | #4 |
Sorry, I'm no help either. Have one add on lower crank single groove pulley and a single groove water pump pulley. Not much help to you there, good luck in your search.
06-16-2018, 04:19 PM | #5 |
Thank you for looking
06-16-2018, 11:17 PM | #6 |
60-66 Nut
Is the pulley you are needing, the one to drive the power steering pump?
06-17-2018, 06:31 AM | #7 |
According to the installation sheet this single add on pulley is for the same belt to drive the A/C compressor.
06-17-2018, 08:50 PM | #8 |
06-17-2018, 11:45 PM | #9 |
60-66 Nut
In my experience with the short water pump on a small block, the groove closest to the balancer is for the water pump and alternator. The second groove out, I always assumed was for A/C using a 2 groove WP pulley. The third groove out is for the power steering pump with a single groove pulley. I'm not saying your illustration is wrong or there isn't another configuration. This is just my experience. Are you needing a total of 3 or 4 grooves on the crank?
06-18-2018, 05:49 AM | #10 |
I'm trying to work off the instruction sheet. I have tbe double altenator , double power steering , double crank + single , just needing the single add on for the water pump as I have a double presently.
06-19-2018, 12:04 AM | #11 |
60-66 Nut
OK, now I see what you are doing. I misunderstood originally. Is the add on pulley the same diameter as the 2 groove WP pulley?
06-19-2018, 06:17 AM | #12 |
I would assume it is. Saw some add on pulleys in a yard yesterday with a square nose instead of tapered like in the picture. They were smaller diameter. Gonna measure mine to compare.
06-19-2018, 12:07 PM | #13 |
1 1/2 inch inner depth
7 1/8 inch outside diameter
06-19-2018, 05:38 PM | #14 |
Heres what it looks like on a 1964. Many Truck pulleys for AIR and PS are truck Only pulleys , not always the same as cars. This add on pulley was used on 1958-1961 passenger cars= Impalas with Cool Pack units and 1963-1966 Truck dealer installed air. The GM part number is 3779582.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK Last edited by 60-66; 06-19-2018 at 06:10 PM. |
06-19-2018, 05:38 PM | #15 |
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
06-19-2018, 05:40 PM | #16 |
06-19-2018, 07:15 PM | #17 |
thank you Jon, been looking through the parts books unsuccessfully today trying to find that number. So far my pulley purchases are plenty and no result yet. lol
06-19-2018, 08:39 PM | #18 | |
06-19-2018, 08:41 PM | #19 |
By the way Jon , I got to meet Roland. Nice guy , speaks fondly of you.
06-21-2018, 05:51 AM | #20 |
Sourced the pulley with the part number out of Tulsa Oklahoma. It's on it's way. I'm off to Texas.
06-21-2018, 07:15 AM | #21 |
got time for texas but not Detroit, I see how you are...
06-21-2018, 07:27 AM | #22 |
I should have brought you sanitary napkins. Roll a Depends instead. Lol
06-21-2018, 10:14 AM | #23 |
there called adult under garments and i change mine daily, enjoy ur trip!!
06-21-2018, 10:56 AM | #24 |
Why yes he is ! Hes on here once in awhile I think .Glad you found your pulley !
