06-19-2018, 10:53 AM | #1 |
meowMEOWmeowMEOW
HP Tuners V4 is out! NGauge Support!
Alright you most of yall know that I'm kinda partial to HP Tuners, and I've usually had access to alpha and beta versions of the VCM Suite and scanner.
Up until know probably 99%+ of the GM ls swaps have been done using v3.xx of the software, and the MPVI or MPVI Pro (the dongle/box). Which has been great but has certain limits. The software began to look a little dated, certain things didn't optimize well for new touchscreen laptops, and lacked hardware support for some oddball computer setups. The MPVI boxes could hold 250 tunes, had a bunch of wires (especially if you had Pro with external wideband input). So.... HPT finally dropped V4.x of the VCM Suite/scanner, the first full-build release in a longtime. It has expanded support for the new tables we need in GenV swaps, easier use of the GenIV GMVE tables, and a bunch of backend stuff I don't understand The other huge change as part of this is the release of the MPVI-2 This new unit stores around 4x as many tunes, and connects WIRELESS to your data port. No more sitting with a pile of wires on your lap, and no more dragging wires through the window when its on the dyno. AND the support for GM protocols is now working on the NGauge. This is a multi-readout gauge similar to the ScanGauge, but can store 5 tunes on 6 licensed vehicles; log and flash without a laptop, and monitor 32 PID's simultaneously. This info kinda gave me a chubby.
06-19-2018, 11:53 AM | #2 | |
Re: HP Tuners V4 is out! NGauge Support!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-19-2018, 05:25 PM | #3 |
meowMEOWmeowMEOW
Base price is $299, but there are trade-in upgrades available. For folks that make use of things like SD Enhanced OS, wideband logging etc (basically the old PRO features), its worth waiting a short while.
The new hardware won't have a standard and Pro. Instead all units will be the base module, with something called an "expansion hub" for the addition of the wideband, onboard logging support, livetune etc. This was driven by HPT's sales being like 70% base units, with the Pro units usually going to shops or the racing community. The hub has not released yet, so if you use those features probably worth a month or two until its available.
06-20-2018, 02:21 PM | #4 |
never understood someone buying HPT and NOT buying the Pro version. In my opinion, HPT without wideband support is pretty limited in it's use. <shrug>
06-21-2018, 11:41 PM | #5 | |
BMW & ASE Master Certified
Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
06-22-2018, 08:55 AM | #6 |
Brew that is some interesting information. I am a "causal" user and have done a few swaps and helped some friends so my knowledge of HP Tuners is somewhat limited. I do have the pro version and use it for my turbo setup. I will do some more research.
Thanks Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
