06-19-2018, 09:49 PM | #1 |
Gas Pedal Holes
Just Wondering What The Holes Around The Gas Pedal Are For?
I Upgraded To a Cable Setup Instead Of The Rod and Bought The Adapter Off A Site Member To Use It on My 69c10 Posted via Mobile Device |
06-19-2018, 10:20 PM | #2 |
Re: Gas Pedal Holes
The small holes in your pic are for the fire wall insulation retainers. The large hole by the three threaded holes is where the gas pedal linkage passes through (not used with a cable)
Here are some pics of a 72: |
06-20-2018, 12:43 AM | #3 |
06-20-2018, 10:24 AM | #4 |
Thank You
06-20-2018, 10:57 AM | #5 |
Old member
Re: Gas Pedal Holes
I bought the Lockar pedal assembly. I had the factory cable so it was a direct replacement. You will cover up the old rod hole and have to drill a new cable hole.
