Old 06-20-2018, 01:55 PM   #1
motormouthfab
Neutral Safety Switch termination for Lokar Floor Shifter
C10 Guru's,
Looking for some help with the Neutral Safety Switch installation/wiring for the new Lokar floor shifter I just installed. I'm thinking I can land the switch wiring from my Lokar shifter NSS to the Ignition switch in place of where the stock neutral safety switch from the steering column lands right? I know where the switch is in the steering column but it is just wired to the ignition switch so it seems simple but just want some re-assurance and hopefully a pic/diagram on where to land my 2 wires from my Lokar NSS. Any help would be much appreciated as I have learned so much from this forum since purchasing my dream C10 about a year ago and diving in. Cheers
motormouthfab is offline   Reply With Quote
Old 06-20-2018, 01:58 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Neutral Safety Switch termination for Lokar Floor Shifter
I ran 2 wires from the stock NSS plug located under the dash, and ran them under the carpet to the micro switch on my B&M Pro Stick. Works perfect.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-20-2018, 03:44 PM   #3
72LB
72LB's Avatar
Same thing I did ran two wires from the NSS plug to the shifter.
1985 C10 shortbed, current project.
Member of the Upstate SC GM Truck Club.
72LB is offline   Reply With Quote
