Mechanical Fuel Pump Failure
I just put a brand new mechanical fuel pump on the 350 in my '72. Nothing fancy, just a NAPA OEM type. It ran great for maybe a hundred miles and now it's shooting gas out the weep hole. Would the diaphragm have failed that quickly?
Re: Mechanical Fuel Pump Failure
It’s happened to me before on my 53 Kaiser. I’ve had a few bad experiences with mechanical Napa pumps. Still under warranty hopefully?
1953 Kaiser Manhattan “Sled” 1968 C10 CST LWB 1991 Trans Am GTA “White Nasty” 2006 Dodge Charger RT Built TH400 for Sale |
If I want to keep it mechanical, what's the best one to get?
I used a precision fuel pump after having 2 failed Napa pumps. Got it from o Reilly’s. Two years and still going strong. Don’t drive the car very much though, too afraid to damage it and parts are almost irreplaceable.
AC Delco
![]() Join Date: Feb 2012
And don't forget a fuel pressure regulator. Most fuel pumps put out more psi than the 5-6 psi that a typical carb requires. Causes a lot of carb. problems.
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom) 1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK. 1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive ! |
![]() Join Date: Sep 2015
same problem here with a auto zone fuel pump. I installed a a/c delco pump and no more problems.
I've had great luck with Holley fuel pumps. 7.5 psi no fuel regulator required.
![]() Holley Mechanical Fuel Pumps 12-834
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
![]() Join Date: Dec 2012
Or even an Edelbrock - mine works great - no regulator for the carb.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
68 K20 Custom Camper/CST Wrecker. 97 GMC K1500 short bed reg cab. |
![]() Join Date: Feb 2002
Had the same thing happen to me a few months ago. Old pump [350 V8 in '71 GMC Jimmy] worked about 11 years, then gave out in downtown rush hour traffic. Got towed home. Replaced it with one from O'Reilly's, and got about 100 miles before it was showering the lower engine bay with 93 octane gas! China. Got towed home again, and got my money back from O'RAP, then got a Delphi from AutoZone. They assured me it was made in Troy, Michigan. As I was applying RTV to the gasket, I found the fine print on the box: Korea. But it works OK so far.
They just don't make 'em here anymore. [That may change due to politics, IDK.] Where they are being made, they ain't making them right, for the most part. I think it's a plot to make us all drive Priuses.
get a carter if you can find them, don,t know if holley or edelbrock bought them out
"Send in the clowns the goats are loose" |
#13 | |
Federal Mogul bought Carter out, but still marketed Carter AFB carbs. I looked for a new AFB in 2005, but had to get an Edelbrock. I haven't seen a Carter mechanical pump in years. I hope it's just me and I've been looking in the wrong places. But I dunno.
#14 | |
#15 |
Thanks. I should get one to keep in the between-the-seats-console just in case my Asian one decides to join its most honorable ancestors.
#16 |
Scrapper 1
Can I say this two word's CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico CHINA/Mexico
#17 |
I have a electric fuel pump installed inline before the mechanical. I have had the same proplems with the mechanical types.When they die, its always in traffic. So now when that happens, i just flip the switch to the electric and im good to go. Mechanical fuel pumps of today are unreliable.
#18 |
I bought cheapo pumps from several vendors, 20 bucks they cost and they lasted about 3- 7 months. paid almost 50 dollars and it lasted 6 years......
#19 |
I use Carter electric. Flip the switch, wait about 10 seconds, Pump the pedal twice and it lights right up with a turn of the key after sitting for weeks. Been using these for 30 years. My old 58 has a mechanical for nostalgic reasons but that is the only car I cannot get to run right. I am having all sorts of issues with pump pressure and the Edelbrock carb.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
