Old 06-28-2018, 10:16 PM   #1
jkohnz
Cab modification question
I have what will probably be a stupid question, but since I couldn't find the answers via google, here I am. I don't know a lot about these trucks yet and am learning here. Please don't blast me too hard lol.
I am planning on using a late model frame for my 68 truck project. The question I have is, the channel under the cab is obviously not wide enough to sit down all the way on the frame I'm using. But, it looks like the back of the cab could possibly be trimmed to allow it to fit? Hoping to tuck the frame up in there a bit. I think the frame width at that point is around 34"? Probably wrong, but I couldn't read the pics (too blurry) I saw in another post here. Is trimming about 3.5" off each side doable?
jkohnz is offline   Reply With Quote
Old 07-01-2018, 10:37 PM   #2
jkohnz
Re: Cab modification question
Kind of shocked I didn't get any kind of response at all... I don't have a cab yet, so trying to plan accordingly. Thanks in advance.
Old 07-02-2018, 05:58 AM   #3
Grumpy old man
Grumpy old man's Avatar
Probably need more information on what frame your using , But in reality it's just a big piece of metal and if you have the equipment /time and ability anythings possible , You could add 57 Caddy tail fins and Mercedes gull wing doors if that's what you want to do .
Grumpy old man is offline   Reply With Quote
Old 07-02-2018, 07:18 AM   #4
panhead59
Yeah not to many people "channel" anymore. Not at home anyway. It just doesn't make sence to do all that work when getting, basically, the same results by available pre-fabbed lowering and suspention kits.
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom)
1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK.
1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive !
panhead59 is offline   Reply With Quote
Old 07-09-2018, 07:07 PM   #5
jkohnz
Using a 2002 Cadillac Escalade frame. Really trying to see the width of the OE frame at the back of the cab.
Old 07-09-2018, 11:01 PM   #6
Grumpy old man
34" outside of frame rail to outside of frame rail , body mount at rear of cab center to center is 37 1/2"
the Escalade wheel base at 116 is pretty good length wise
the easiest way to go about this is to sit the 68 body on the frame and cut away anything that doesn't look like a 68 truck .
Old 07-10-2018, 01:33 AM   #7
stsalvage
Scrapper 1
stsalvage's Avatar
Problem about using a newer frame.There made to Fold with the sliest bump or Fender bender.All that work in building it and some one barley hits you at 15 MPH.The frame is JUNK.I have a real problem about taking a stiff frame and taking it out for a crinkle frame that is made to bed to Protect you.Funny thing is Taking a stiff well built body and putting it on a lack luster frame.Careful you don't bend the frame from the heavy metal you place on it you Might want to close up the frame to make it more ridge to handle the heavy weight
stsalvage is offline   Reply With Quote
Old 07-10-2018, 07:40 AM   #8
jkohnz
Not sure what you mean by closing it up. Frames on these model SUVs are fully boxed, not c channels. I'm probably missing your point.
