Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 07-20-2018, 07:45 AM   #1
tk1251k
tk1251k's Avatar
1988 s10 not starting
Right after adding gas and getting onto interstate up to about 70 mph it just lost most of its power still run but mot much power. Got it off to the side of the busy highway. SO far changed the fuel filter no help. Getting gas runs briefly on idle then cuts off. We got to run about 20 mph to get off the highway by feathering the gas. Had it towed home last evening. Now the fun begins. All hoses seems ok but I need to check closer. Truck ran great up until that point. Has only 34,000 miles on it. Any suggestion tips or help appreciated. Thanks in advance.
tk1251k is offline   Reply With Quote
Old 07-20-2018, 06:55 PM   #2
tk1251k
tk1251k's Avatar
Re: 1988 s10 not starting
I unlugged the water temp sensor the truck fires right up. Got a new sensor plugged it up the truck is same as before. Idles high but runs at least. I suppose ecm thinks is minus temps. Checked for vac leaks none that I can find.Out ideas at this point. I want my 72 truck back.
Old 07-23-2018, 07:30 PM   #3
tk1251k
tk1251k's Avatar
Anybody have any answers or is this a silent crowd? I hooked up test gauge just before fuel filter I get 0 tring to start the engine. I unplug the eater temp sensor still get 0 but the truck starts right up. Any ideas before I trash this heap.
Old 10-17-2018, 11:44 PM   #4
76C10Stepside
76C10Stepside's Avatar
Only just saw your post.
Which engine do you have? How many miles on the odometer?
If it was carbureted, you could easily test it with some fresh gas to see if the cause of your problem is tainted gas.
76C10Stepside is offline   Reply With Quote
