Old 08-02-2018, 07:11 AM   #1
hogfarm
inter fenders
As I am putting the front clip on my 58,things are lining up OK.I did weld all the fenders and grill support together and included the inter fenders.well where the bottom of the inter fenders and the cab meet the holes don't line up I did have the brackets off and do to my age I don't know if I put them back on right.could someone get me a picture?
hogfarm is offline   Reply With Quote
Old 08-02-2018, 11:15 AM   #2
DransportGarage
DransportGarage's Avatar
Re: inter fenders
"Install the lower firewall brackets such that nuts are on the driver's side of both brackets."
This is true for '55 second series trucks. Maybe a '58 owner can confirm that this is true or false for a '58. Sorry, no picture. My truck is apart.
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 08-11-2018, 02:21 PM   #3
_Ogre
_Ogre's Avatar
Re: inter fenders
not good pictures of either bracket, you can see them both, yes they both go the same way, not mirrored
not sure what you welded up, most of the bolts holes are slotted for adjustment purposes
you may have a problem lining up fenders and door gaps
shop air compressor timer
Old 08-17-2018, 01:29 PM   #4
OrrieG
OrrieG's Avatar
Re: inter fenders
What Ogre said, just about everything has to be loosely bolted so you can get the door and hood gaps right and body accent horizontal line to line up with the door line. I had to add shims between the radiator brace and inner fenders/fenders to get the hood gap right and square. Firewall brackets go the same way not mirrored too.
OrrieG is offline   Reply With Quote
