Old 03-20-2002, 05:52 PM   #1
pinky350
Post ?? Radiator??
Last week someone posted about the best way to run their heater hoses. To the water pump and the intake OR to the rad and the water pump and or the intake. I did not know that 67-72 pickups had the radiator with a place for the heater hose.Or do they? And I think some one said that if you run to the rad with heater hose that it would help cool it better> Is that true?
pinky350 is offline   Reply With Quote
Old 03-20-2002, 06:57 PM   #2
Fast68Chevy
Fast68Chevy's Avatar
Post
some do and some dont, the 72 blazer 350 4x4 had hooked ot radiator instead of to the pump, its the 3/4" hose(larger of the two) that was either on pump or radiator, you can connect however you want to depending on radiator you have, have to pipe plug the pump fitting though if you conenct to rad
good luck
-71/C-10(thx teeitup and crews!)350 4+4/CH465(thx 71Chev, GMCPaul, and CPNE)longfleet bed(thnx meathead95)!still building it-
-'84 Z28(Z28) 1G1AP87GXEL100000 with H.O. 305/4bbl/190net/hp(L69) 3.73 rear(GT4/YC4) 700R4(MD8-MXO) & other goodies
-79 G20 pass van, 350/th350/10bolt,
paint is overrated
Randy- Lincoln, IL
randy@ccaonline.com
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
Old 03-20-2002, 08:01 PM   #3
pinky350
Post
Thanks Fast but does it cool any better running to the radiator then the water pump?
Old 03-20-2002, 09:39 PM   #4
BubbaGreen
Post
Dont really know if it cools any better but
seems to me I read somewhere, the idea behind
having the connection to the radiator was
mostly done for automatic transmissions...It
would bring the transmission fluid up to a
stable operating temperature quicker by passing warmed coolant from the manifold
directly over the autotrans fluid cooler
inside the radiator...Looking at the service
manual for these trucks, 4x4 were done this
way....and I also think the bigblocks were
also routed the same. Although not certain.
I like the hose routed to the radiator
myself. I just think it looks cleaner.
71 Chevy C-10 SWB Fleetside WAS:307w/3-on-the-tree NOW:350TBI/700R4/3.73
See it at www.prismnet.com/~grzanich
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
BubbaGreen is offline   Reply With Quote
Old 03-20-2002, 09:45 PM   #5
da-burb
"Ochre Ogre"
da-burb's Avatar
Post
My opinion is that it would cool marginally better. In warmer months you wouldn't be using your heater, so the water entering your water pump from the 3/4" return hose is almost the same temp as when it left the block. So if it returned to the radiator, it would mix with the already cooler water and lose some heat to the radiator. I don't think it would be much however. It isn't passing through any cooling fins, it is just being dumped back into the right radiator tank and out the bottom hose again.
1971 C-10 Suburban
1972 C-10 Suburban
1969 XL Galaxie Fastback
1968 Galaxie 500 Fastback
1974 SCOUT II
Montrose, Minnesota
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
