08-29-2018, 07:23 PM | #1 |
Champion Spark Plug Cleaner
Just picked up this little Champion spark plug cleaner. I know plugs are cheap for the most part but I do a lot of small engine jobs and figured I'd give it a try. Any ideas as to what media to use in it? It had a mix of sand and black beauty like stuff in it. Would glass beads be too fine?
Thanks Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
09-04-2018, 08:49 PM | #2 |
Re: Champion Spark Plug Cleaner
Glass beads will be perfect. Sand or Black Beauty are too coarse.
09-05-2018, 08:24 PM | #3 | |
Paul
02-06-2019, 03:31 PM | #4 |
I have alsways wondered about bead blasting sparkplugs...wouldn't you run the risk of gettting beads stuck "up in there" that would eventually end up in the cylinder?
I have heard of blasting plugs often enough just never had the nerve to do it myself. Wire brushes, bench grinder wire wheel, and some brake parts cleaner work fine when needed.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
02-09-2019, 12:12 AM | #5 | |
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
02-09-2019, 12:38 AM | #6 |
The little unit I picked up has two buttons. One blasts the glass bead and the other just high pressure air. Before reinstalling the plug I always inspect it and take a close look at the inner insulator. It only gets used on small engine plugs though.
Paul
02-09-2019, 12:53 AM | #7 |
They are still used in the shops of airplane mechanics.............
https://www.aircraftspruce.com/catal...xoCADcQAvD_BwE https://www.youtube.com/watch?v=98iztkS3OfI
http://i204.photobucket.com/albums/b...baae5d9a7e.jpg |
02-13-2019, 08:56 AM | #8 |
When I was in highschool in shop class, back when schools still had shop classes, we had one of those and it was just glass beads followed by compressed air. Two button style like mentioned above. I would think anything more than glass beads would be too abrasive on the small gas engine plugs with such soft metal used.
