Old 09-12-2018, 10:46 AM   #1
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Flexplate Question
I have an 03 LQ4 that came out of a Denali Yukon. I assume it had a 4L60 behind it. I am going with a 4L80e. I am changing out converters, so the new one should be a 3 bolt pattern converter from Circle-D. My flexplate only has 3 holes for the converter now. Do I need a different flexplate for the 4L80 or will the one I have work. The plate I have has #TU2824G stamped on it. Thanks
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 09-12-2018, 01:17 PM   #2
4x4k30
4x4k30's Avatar
Re: Flexplate Question
you will need a 6.0 flex plate it has 6 bolt holes and the 4l80e converter uses 6
4x4k30 if trouble was money i would have plenty
4x4k30 is offline   Reply With Quote
Old 09-12-2018, 02:53 PM   #3
1971Stepside
Almost Satisfied
The LQ4 is a 6.0. I understand the newer converters for the 80 have the three bolt set up. This is what I am trying to confirm.
Old 09-13-2018, 10:38 AM   #4
1971Stepside
Almost Satisfied
I called Brian Tooley this morning and they said the Circle-D converter just has 3 bolts instead of the six so I should be fine. He didn't give me a warm fuzzy, but I will order the converter and see what I get to work.
Old 09-13-2018, 11:08 AM   #5
beaterku
beaterku's Avatar
Depends on which Circle D converter you are buying. The HP series 278mm only fits the dished 60e style flex plate. The pro converters fit the flat 80e flexplate.
beaterku is offline   Reply With Quote
Old 09-13-2018, 11:33 AM   #6
1971Stepside
Almost Satisfied
It is the 278mm series according to the quote they sent me. So, it should work?
Old 09-13-2018, 11:35 AM   #7
beaterku
beaterku's Avatar
http://www.circledspecialties.com/4l80-hp-series-278mm
Towards the bottom of the page "ONLY fits the dished LS style flexplate"
Sounds like you are good to go.
Old 09-13-2018, 11:55 AM   #8
1971Stepside
Almost Satisfied
Here is what I have. Thanks for your help.
