Almost Satisfied
![]() Join Date: Mar 2002
Fuel Lines...stuck again
I did extensive searching on the forum and found all the parts that I thought I needed to run my fuel line from the engine (non-return) to my tank (in frame).
I ordered Russel fittings from summit and Summit's PTFE braided hose. Well, the hose doesn't fit the fittings. I called Russel and they told me that PTFE hose won't work. I asked them what hose they recommended and they said to use solid aluminum hose to avoid the fuel smell. So, do I send back all of my fittings or do I order different hose? I don't want the smell in my garage. If I need different fittings, I don't see Russel fittings that work with PTFE hose. If I order new hose, where/what? Does someone make a solid line that will run from the cab to the rear of the frame? One step forward...three steps back.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
meowMEOWmeowMEOW
Re: Fuel Lines...stuck again
PTFE hose uses fittings with a different ferrule on the hose end. I think on summit you can specify hose type when searching fittings.
I run braided line from pump up to my frame, then 3/8 hardline up to the firewall, with another section of flex going from firewall to rails.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Almost Satisfied
Brew...I only see that Aeroquip makes these. I don't see them for Russel? Am I missing them? Also, do you have any fuel odor due to the braided line?
Post Whore
![]() ![]() Join Date: May 2015
Im using all steel braid...no smell...I would think if you can smell gas then you would also have explosive vapors in the air....one good thing about summit...they'll take back just about anything if you need to send it back..
Almost Satisfied
Mongocanfly....to clarify, you are not using PTFE line, correct?
Post Whore
No...steel braid from tank to rails
I followed the advice of the veterans on here and purchased AN fitting and a black braided steel line.
Here is the hose I purchased on Amazon https://www.amazon.com/SUNROAD-Unive...ess+steel+hose. I purchased all of the AN fitting on Amazon too. I think some came fro jegs via amazon.. The AN route is not cheap but its easy to work with once you figure out the fittings and whats available+ its bullet proof if installed properly. I purchased the Speedway corvette filter /pressure reg and walbro 392 combo kit - It had a few AN's with it . If you have the option to run an in tank pump - I would go that route instead. My Walbro 392 is a bit whiny. + when you add it all up I think I spent about 300 total with hose, filter, fittings etc. You can run an intank pump for that .
![]() 1965 fleetside Sold |
Almost Satisfied
Thank you 65blackfleetside. How long have you ran this hose? Are you getting any fuel odor from it? I have all of the AN fittings from Russell already.
i got the dorman fuel line repair kit and 2 rolls of 3/8 and 5/16 line and made my own nylon lines just like o.e.m has been doing for years . pressure tested before body on truck and no leaks . and truck runs no leaks .
i have around just under 300 in the whole kit setup from dorman . and later on i can make more / fix others / replace ends as needed . so its a win/win/win . but each to there own on brand / product you wish to run . my combo is intake pump 60psi 29lph 3/8 feed 5/16 return to aftermarket efi system feeding 300hp gm new engine .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
I bought the lines from Tanks INC. that they recommended.
Post Whore
On my current build I'm using the black braid hose instead of Stainless outer ...i got all fittings and hose from jegs...
Almost Satisfied
Alright. I ordered the Russell ProFlex braided -6AN hose. We will try it. I guess if it gets stinky I can replace a big portion of it with solid line later. I did call a couple places and they said it was the ethanol in the gas that was causing the breakdown and most newer hoses were handling it better than a few years ago, but both did say that overtime the corn would break the rubber down. So, buying good gas is the trick maybe???
#13 |
meowMEOWmeowMEOW
Honestly I have no clue if the lines contributed to vapor at all. I've had a few vehicles that used them and never really thought about it. When parked, my truck has an open vent off the tank, so on a hot day you might smell it a tiny bit, if your near it (like, head in the bed).
Running my truck for any length of time makes everything in the area smell like gas so I have no clue.
#14 | |
I ran the same line from tank to fuel rails. For me, it was a bit more difficult to work with having a black nylon sleeve rather that just braided stainless. Worked out great though. |
#15 |
You have to run fittings matched to the line you are running, its not advised to mix and match hose fittings and hose when making lines. You can use different brands of adapters (AN to AN, NPT to AN, etc.), but when it comes to the actual hose fittings themselves they should match brands to the hose you are using.
The reason its important to run matching hose ends and hose is that each brand of hose is made differently then the next, and for that matter a certain brand might have 2 different models of similar hose, but they take different specialized fittings. PTFE is an inner liner impervious to all known fuels, oils and coolants used in automotive applications. This will stop any vapor from seeping. The outside braided stainless or braided nylon has zero effect on vapor seepage. It is simply an outside wrap for protection. |
#16 |
Almost Satisfied
Trying this from my phone. Mocked up my lines a little tonight. Thoughts on distance from headers and clearance for shift linkage?
#17 |
Where you come close to the header you could run some of the aluminized fiberglass wrap, I ran some on mine, not sure how much it helps but I would think it would make a difference.
#18 |
![]() Join Date: Sep 2005
i used the summit ptfe braide hose and ordered the summit brand fitting for it ive had no issuses with my set up
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
