11-17-2018, 10:00 PM | #1 |
Anyone running a carbureted LS motor?
I hate the look of the LS intakes and fuel rails but I do like the distributor-less design of the LS ignition so I am thinking of putting in a carbureted LS motor. Hope this doesn't sound like a dumb question but if I put a carb on an LS motor with the MSD LS ignition coil kit do I still need the factory computer and harness or does the MSD kit replace that? I understand I will need a standalone controller if I use a 4l60E for a transmission. I know I am going to get some negative feedback on this so here we go!
11-17-2018, 10:10 PM | #2 |
Post Whore
Re: Anyone running a carbureted LS motor?
Don't like the LS look?....read dayj1's build.....http://67-72chevytrucks.com/vboard/s...ght=Skin+a+cat
11-17-2018, 10:30 PM | #3 |
Really nice build. I'm trying to keep it as simple as possible as far as wiring goes, just wondering if ill still need the ECM with a carbed setup.
11-17-2018, 11:40 PM | #4 |
need a spark controler box at min for the fact there i no dist setup .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
11-18-2018, 08:16 AM | #5 |
No hate here . I have both fi and carb and like both .Both are built for performance . The carb engine is in a 67 camaro and fi is in my 82 c10 . The carb engine is a little monster with a 4 speed .
So nothing wrong with a carbed LS engine in my book . As for controller I use the MSD 6010 for the 24 crank reluctor wheel . It comes with the harness you need to plug into your existing sensors . There are some newer versions with the option on reluctor . There is also some other company's that make systems also . Just be sure to get the right one for your reluctor . So in the end to answer your question , you do not need any part of the oem harness or computer . As you already stated you will need a controller for the trans if automatic . |
11-18-2018, 10:46 AM | #6 |
There is NOTHING about a carb that would EVER make me want one when good, calibrated EFI is available. Point being once the air cleaner is on, there's not much difference.
11-18-2018, 11:14 AM | #7 |
Post Whore
I agree...putting a carb in place of injection defeats all the benefits of having a LS....if i wanted a carb I'd just keep a SB....
11-18-2018, 12:02 PM | #8 |
Big difference in power and torque between a sbc and ls even when carbed . Dont get me wrong , I like the efi as well . Its just another avenue with the ls motors .
11-18-2018, 12:11 PM | #9 | |
2%, or even 5%, at wide open peak output only should matter only to heads-up drag racing, really... If you want a carb, get a carb, none of my business. I just want to disabuse anyone from the notion that the car will be faster, better, stronger, or really in any way improved by a carb over EFI.
11-18-2018, 01:03 PM | #10 | ||
If you will read my statement again it is not comparing efi to carb . It is comparing small block chevy carbed to ls carbed . There is a lot of difference between the two in stock form even when carbed . In no way I was saying carb was going to make more power over efi . |
11-18-2018, 03:22 PM | #11 |
thanks for the info guys.
