Old 11-25-2018, 11:04 PM   #1
56hotrodred
700r4 transmission & 350 ramjet engine installation
I am looking for information on how to properly connect my 700r4 to my 350 ramjet engine.
I have been researching and reading about the throttle cable, TV cable and am also finding info about a kick down cable!
Does anybody have any good pictures of how the throttle and TV cables are hooked up to the ramjet 350 engine?
Do I also need a kick down cable?
I do have a throttle cable and bracket from Lokar and the transmission came with a TV cable already installed!
I also ordered a kick down cable from Lokar but again am finding conflicting information on using it.
I have PM'd Ogre for information as he has this same combination and am waiting to hear back from him.
Any assistance would be appreciated and a good picture or two would be great.
Thanks in advance.
56hotrodred is offline   Reply With Quote
Old 11-26-2018, 02:56 AM   #2
bobinbc
bobinbc's Avatar
Re: 700r4 transmission & 350 ramjet engine installation
700r4 doesn't have a kickdown cable only TV cable. You need to make sure your Lokar throttle cable bracket is also TV cable bracket. Not sure of the part number right now but I think I had one on my 65 Nova. Maybe check Lokar website? I don't have any experience with the Ramjet engine, doesn't it come with brackets on the fuel injection for the cables?
1962 Chevy blue SBFS
1957 Chevy yellow SBSS
1956 GMC red SBSS Nov 2017 ToTM
https://www.facebook.com/groups/Cana...geChevyTrucks/
bobinbc is offline   Reply With Quote
Old 11-26-2018, 09:38 AM   #3
Driver_WT
Driver_WT's Avatar
Here is some info for you http://www.tvmadeez.com/about.php and some more http://www.tvmadeez.com/accel-1000_cam/
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes
Driver_WT is offline   Reply With Quote
Old 11-26-2018, 01:18 PM   #4
56hotrodred
Hey thanks for your responses.
I did just contact Lokar and they said that their "GM EFI Hi-Tech Kickdown Kit" that I have is listed to cover several transmissions, including the 700R4, does in fact function as a TV cable on my transmission.
Problem solved. Except for the final adjustments needed to set it up properly. One step at a time...
I should have asked them first off. I figured somehow that I needed both and could not see a way to hook both up.
I should have everything I need all ready.
Old 11-26-2018, 01:24 PM   #5
Driver_WT
Driver_WT's Avatar
That's great. I think there is some good info on the links I provided that will help you set up the TV cable.
Old 11-26-2018, 01:51 PM   #6
56hotrodred
Yes absolutely!!!
I have already looked at them and will be printing them off to set things up. I was a little scared about removing the stock-looking black TV cable and replacing it with something else, now the cable I have, but it actually does not look too bad.
Going back out real soon to install pedal, two cables and new bracket on engine.
Then I will have to fine tune down the road.
I just got confirmation from the body shop that its not a big deal that the truck will not be running when they get it back for the remainder of the body work. I was thinking that I could have it running but not all the bugs worked out. I was worried that they would accidentally screw something up even with their short starts. He said they would push it from booth to booth.
So I might put fluids in engine and prime it and fill the transmission then wrap them in plastic to keep the dust out. I hate that sanding dust! It gets everywhere!
I have a month to get it to them.
Old 11-26-2018, 07:18 PM   #7
_Ogre
_Ogre's Avatar
i posted the info you needed in my thread before i saw this
ididit has a ramjet bracket
i was out of town for the past 4 days, didn't see your pm
shop air compressor timer
Old 12-02-2018, 10:20 AM   #8
Leonardoo
You can find a video of how to adjust the cable and other common problems and troubleshooting with the transmission here. PM me for more information also if you want
Source
Leonardoo is offline   Reply With Quote
Old 12-05-2018, 02:49 PM   #9
_Ogre
_Ogre's Avatar
did you get the bracket? everything should fall into to place
