Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-03-2018, 08:55 PM   #1
87Flh
87Flh's Avatar
lockers
Anybody here use a rear locker? Been researching Spartan and Powertrax lockers as a cheaper and easier alternative to a LSD. Most of the info out there is from offroading sites.People seem to either love them or hate them.
My truck is 2wd/4spd and daily driven. Pros? Cons?
87Flh is offline   Reply With Quote
Old 12-05-2018, 09:12 PM   #2
Mike C
Mike C's Avatar
Re: lockers
I have a Powertrax NoSlip in the back of my CJ-5. Mostly it isn't noticeable, but every once in awhile it pops and acts funny. It's not as bad as I thought it would be. But you need to be pointing straight when you get in the throttle. My jeep doesn't get that much road driving time and I picked up front and rear axles with NoSlips, gears, brakes, aftermarket axles, wheels and tires for $800 so that made sense to me.
I have one in the back of my K30 dually and it does all sorts of wonky stuff with the extra wide truck and dual wheels. Truck is off-road only farm beater.
They are only as strong as the stock open diff case and spider gear pin as most don't come with a hardened pin.
Personally, I would not run one just to save money. The LSD is the right answer. Either a clutch type or a TruTrac is what to spend your money on.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-06-2018, 08:36 PM   #3
87Flh
87Flh's Avatar
Re: lockers
Thanks for the reply.
I think I am gonna go with this setup, https://www.ebay.com/itm/NEW-GM-8-5-...gAAOSwKIpWEd9w.
probably not the best, but for the money it should work for me.
