12-09-2018, 04:04 AM | #1 |
Enjoying left field
Cold weather troubles
Having a weird issue. I have a 2000 Silverado with a 5.3. Just recently moved to SW Montana where it gets pretty cold. The last few mornings it's been around 0°f and my truck won't start. Cranks but won't fire. But in the afternoon once it warms up to 20° or so it starts and runs like nothings wrong. No relevant codes when I scanned it. Any ideas? Could this be a VATS issue?
12-10-2018, 05:53 AM | #2 |
Moderator
Re: Cold weather troubles
When the Passlock activates it stalls the engine and some kind of message will show up on the instrument cluster.
Have you checked whether your ignition coils have fire? Injectors activating? Break out your scope and check the crank position sensor and cam position sensor and wiring when it's acting up. A scope lets you look at voltage changes over time as a waveform from crank and cam position sensors and the like. I already have a DSO203 for other work and I'm acclimated to it so I use it. Not the best for automotive work but it's what I have. If you are just buying a scope to do automotive work I'd invest in an automotive scope rather than a generic unit like my DSO203 for around the same price... The generic units have a steeper learning curve. Not that the automotive variety is super simple but it likely has presets to do some common automotive diagnostic tasks that a generic scope would require actual training or experimentation to setup.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 12-10-2018 at 02:36 PM. |
12-10-2018, 08:23 AM | #3 | |
Does it sound like the engine dragging slow when cranking ? Battery could be a factor as well at those temps . Or a combo of both . |
12-10-2018, 11:24 AM | #4 |
Enjoying left field
It drags a little, but I've had slower starts. Its warmer this week. Probably 35 this morning. It fired right up. I'll check the battery.
12-10-2018, 11:39 AM | #5 | |
If battery it will be a easy fix . Let us know how it goes |
