Old 12-10-2018, 05:03 PM   #1
JWall
Frequent Flyer
JWall's Avatar
Whine Underhood - 2003 Tahoe - Sounds electrical
Looking for some help with this whining noise in the video below.
It's on the wife’s 2003 Tahoe 5.3.
It’s an intermittent noise that sounds electrical to me.
To me, it appears to becoming from top of the engine on the drivers side.
No Check Engine Lights, No codes, No loss in performance & the noise changes little to none with RPM increase.
I’ve checked the common ground behind the passenger side head issue.
I also replaced the alternator & pcv with no effect on the noise.
I’ve seen others say they have this issue but no solutions for it. Thanks in advance!
(Sorry for the weird lighting videoed under a neon sign at night)
https://www.youtube.com/watch?v=tipV1Nuz8C8
- Justin
1 Owner 1976 SWB
Old 12-11-2018, 01:06 AM   #2
allchevy58
allchevy58's Avatar
Re: Whine Underhood - 2003 Tahoe - Sounds electrical
Sounds like a bearing, take the belt off, start it and see if it goes away. Check idler pulley.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 12-11-2018, 10:30 AM   #3
JWall
Frequent Flyer
JWall's Avatar
The issue is it doesn't do it right away when you start it, you have to drive it for a while before it will do it.
And if you turn it off while its doing it (to say take the belt off) it will stop & not start making the noise for a while.
It will also make the noise for a while then stop all while driving & without turning it off.
I guess I can throw an idler pulley at it & see. They are cheap enough. Although this sure doesn't seem belt drive related.
- Justin
1 Owner 1976 SWB
Old 12-11-2018, 10:56 AM   #4
CarolinaHD
Moderator
CarolinaHD's Avatar
Had a 99 suburban and my 04 Tahoe that make similar noises but not as high pitched in that video. Both were the alternator making noise but not the bearings.
Alex
1967 C50 292ci Lumber truck
1967 C50 292ci Dump truck
1967 C60 366ci Fire truck
CarolinaHD is offline   Reply With Quote
Old 12-11-2018, 11:14 AM   #5
JWall
Frequent Flyer
JWall's Avatar
Ever find a cure? Or did new alternator fix it?
My Old & New alternator have no affect on the noise.
- Justin
1 Owner 1976 SWB
Old 12-11-2018, 11:15 AM   #6
CarolinaHD
Moderator
CarolinaHD's Avatar
New alternator fixed both for me. I would do as suggested and start with the idler pulley.
Alex
Old 12-11-2018, 11:46 AM   #7
JWall
Frequent Flyer
JWall's Avatar
I'm going to try the idler pulley, cheap enough no harm in trying.
- Justin
1 Owner 1976 SWB
