Old 01-19-2019, 05:34 PM   #1
GTS61
Front disc brakes on 61
I have a 1961 GMC stepside pickup with a 305 V6 in it. I’m wondering what is the least expensive way to have front disc brakes installed. Like what do I need to buy. I’d like to do it myself. Thanks for all you guys do with helping us rookies.
Greg
GTS61 is offline   Reply With Quote
Old 01-19-2019, 05:52 PM   #2
Macdaddy1
Re: Front disc brakes on 61
I went with auto city classics for my 65c10 but they have the same kits for the 61 as well. In my case it was just easier to purchase the kit from one source than cobble it together from different vendors.
Macdaddy1 is offline   Reply With Quote
Old 01-19-2019, 11:39 PM   #3
MusicMan70
MusicMan70's Avatar
http://67-72chevytrucks.com/vboard/s...brake+spindles
Another link with great info
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 01-19-2019, 11:51 PM   #4
Railroader
Railroader's Avatar
I got mine from Auto City Classic along with power booster. So far well pleased.
If the 61 is like a 63, you will need new rims or rims off 4 wheel drive to clear brake calipers.
Railroader is offline   Reply With Quote
Old 01-20-2019, 12:17 AM   #5
Captainfab
60-66 Nut
That depends on whether you are wanting a dropped spindle or not and whether you want to keep the torsion bars or not.
Old 01-22-2019, 04:18 PM   #6
demian5
demian5's Avatar
So if he gets dropped spindles, can he put the torsion bars back up to a higher level?
Would that result in a better ride?
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 01-22-2019, 07:51 PM   #7
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Yes, he can crank the torsion bar keys back up to the ride height he wants.
With torsion bars it won't change as far as the stiffness of the ride because the load on the torsion bars won't change with drop spindles. However, if he does crank the torsion bar keys back up it will change the geometry of the a-arms - which may not be significant - especially if he never had it aligned after he lowered it with the torsion bars before.
66 C20 Service Truck:
