Tail light problem
I have a question for the masses ? Installed my new tail lights thinking that it’d fix the problem of my passenger side brake light not coming on when I press the pedal but it didn’t. Everything else works on the truck like the signals and the running lights and such except the passenger brake light . Thank you in advanced
Posted via Mobile Device |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Tail light problem
What do your grounds look like?
That is odd because I think there are only 2 wires going to each taillight. the turn signal and brake light run on the same wire.(yellow or dark green)Tail lights would be brown. If you turn the lights on and put on the emergency flashers, are the left and right lights all the same brightness?
1965 C10 1967 Camaro 1998 C1500 2011 Colorado W/T |
The brake light power circuit goes through the turn signal switch so that they keep flashing when when you put on the brakes. Needs to be pintested down on the connector where it easier to get to.
Everybody has to believe in something. I believe I'll have another beer. |
Another thing too is I have to press up on the switch firmly when I want my right turn signal to work , the grounds looks good I cleaned them up with some steel wool I was wondering if I can splice some extra wire onto the ground on on the light and run it to the housing a bit better.
#7 | |
#8 | |
It could very well be that you have a problem in the turn signal. If you have to push hard to get the right signal to work, that indicates an issue there. It could be that the interrupt circuit is causing problems with the right brake light.
If the right signal works, it isn't the wiring in the rear. The problem is either in your signal switch or the wiring harness under the dash. |
#10 | |
60-66 Nut
![]() ![]() Join Date: Mar 2007
I'm going to go with a problem in the turn signal switch.
#13 |
clean all contact points (screws that attach housings and so forth) clean all grounds with sandpaper. That will eliminate any ground issues going forward. Your problem is most certainly in the turn signal switch. replace it and clean clean clean everything.
Check out my build here http://67-72chevytrucks.com/vboard/s...d.php?t=768039 She may not be the prom queen but at least she puts out.. |
#14 |
More than likely it's the turn signal switch.
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1978 chevy c20 350 4speed 1998 chevy c1500 4.3L 5speed 2002 Chevy s10 4.3L auto 4x4 Plus a Mercury & some Fords... To many projects! |
