Starter makes clunking noise
After putting a fresh clutch in my truck the starter has been giving me lots of troubles lately...It starts starts occasionally fine but most of the time it makes a terrible clunking noise from the starter. I swapped starters with it from another truck and tried every combination of shims. Don't really know how to describe the noise, its not a dead battery clicking noise but a clunking sound and the engine still turns over just slowly when it happens. After searching around the internet I couldn't find any solutions so anybody have any ideas of what could be happening?
Re: Starter makes clunking noise
Are you positive everything tight? Flywheel and clutch and all?just trying to eliminate things is all
I am positive I torqued everything to spec and I am sure I would have heard if it was loose when driving it.
Is it a block mounted or bellhousing mounted starter?
Block mounted
Did you use the correct knurled shoulder starter bolts?
You might need a starter brace. A thread here on that. http://67-72chevytrucks.com/vboard/s...d.php?t=492532 |
I used the correct starter bolts but I don't understand what changed that made it not work as it was working fine before with no brace.
Are you absolutely sure you have the right starter. When you say “flywheel” do you mean Flexplate?
I ask this because there are two different starters that will bolt in, but only the one is right. Does the nose cone have a flat spot on the top, so that the starter clears the bell Housing? If not, you have a round nose cone (from a 73-later) and even though it bolts in tight, it will never line up correctly. |
#9 | |
Re: Clunking noise that is driving me nutz
Without hearing a noise video, or being next to the truck to hear what you are describing as a clunk kind of limits me to offering a guess that you can tear to pieces. You've tried shimming and alternative starters and all of that effort has not fixed anything. Maybe it is time to look elsewhere. I think you have a loose flywheel. It's banging back and forth, and when it gets cocked, the starter binds and drags. It's a heavy clutch pack hanging off the back of the flywheel. it wouldn't take much in the way of loose flywheel bolts to present the problem you are describing here. |
Check and re-tighten bolts on my installed an high torque starter off an Escalade on my 87 GMC.......after first crank it started clunking noise on next try.....with shield we couldnt tell it didnt totally seat itself.......re-tighten same been good ever since............
http://i204.photobucket.com/albums/b...baae5d9a7e.jpg |
sub'd
Did you ever get this problem sorted out?
1981 C-10 Longbed, 250 (4.1) 2bbl Varajet, THM-350C. Some of the Build progress: https://www.youtube.com/channel/UC_W...foLyeDq_WQPNmA 1981 Harley Davidson. Credentialed, semi-retired A.S.E. technician. If you don't like free advice, Ask Someone Else and pay for it. |
