01-24-2019, 03:19 PM | #1 |
Why is the panhard crossmember on an angle?
Anyone know why the panhard crossmember is on an angle? Any harm to move the pass side ahead a bit? I could use a bit more clearance for my fuel pump fittings on the tank I'm installing if I push my tank forward slightly.
01-24-2019, 04:17 PM | #2 |
Never Ending Projects
Re: Why is the panhard crossmember on an angle?
It is at an angle to prevent the frame from "racking". Without it, it's the frame is a giant parallelogram. If you were to push hard enough on one end of one frame rail, it would allow it to move. By using the angled cross member, it prevents that from happening, because the cross member would need to physically become longer or shorter, which it cannot do.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
