02-02-2019, 09:41 AM | #1 |
2009
I am kicking around the idea of buying a 07-09 chevy 4x4 extended cab. What should I look for and avoid. I will be doing some towing mainly my 24 foot camper a few times a year. I want a gas burner
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
02-02-2019, 11:22 AM | #2 |
Re: 2009
The 1500 trucks have AFM issues from 07-08. They got better in 09.
2500/3500 trucks got beefier brakes and suspension in 2011. VVT came out in 2010, and its a good system that's trouble free. |
02-02-2019, 04:40 PM | #3 |
Re: 2009
Talk to me like I have driven a 79 ford for the past 17 years. What is vvt and afm
02-02-2019, 06:58 PM | #4 |
Re: 2009
VVT is variable valve timing
AFM is active fuel management. It’s cylinder deactivation. It uses special lifters to keep half of the valves closed in 4 cyl mode. |
02-02-2019, 07:46 PM | #5 |
Re: 2009
Ok. I would really like the 2500 extended cab 4x4
02-02-2019, 10:05 PM | #6 |
Re: 2009
That’s good. All of the 2500/3500 trucks don’t have afm.
02-02-2019, 11:04 PM | #7 |
Re: 2009
I have seen VVT on L96 6.0L's as early as 2008. A 2007-2009 gas 2500 is 'safe'. It will have the 6.0L with the 6L90 6 speed automatic, both very reliable. As others have posted, no AFM.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
02-02-2019, 11:29 PM | #8 |
Re: 2009
The L96 didn’t exist before the 2010 model year. It must have been swapped. The 07-09 6.0 was LY6. They are basically the same engine other than the VVT.
02-04-2019, 03:43 AM | #9 |
Re: 2009
You are right, it was an LY6 that I was thinking of, not an L96. But, LY6's do have VVT. Just did a water pump on a '08 Express with an LY6, and it had the CMP sensor and actuator magnet. Van has been owned by my company since new and I have been the only one who ever worked on it. LY6 is a Gen.IV like the later L96. The earlier LQ4 6.0L is a Gen. III and did not have VVT.
https://gsi.ext.gm.com/gsi/showDoc.d...Syskey=5298860
02-04-2019, 10:35 AM | #10 |
Re: 2009
The link wont work for me.
But I did some more research. The Ly6 and L96 are basically the same engine with different fuel injectors. I learned something new. |
02-04-2019, 01:42 PM | #11 | |
Re: 2009
The link was GM's Fleet website, but I think you might have to be a fleet customer to access. It showed the timing cover assembly of a 2008 LY6.
02-04-2019, 08:28 PM | #12 |
Re: 2009
Yes. Heads and block and gaskets are all the same casting/part numbers. Different injectors.
02-06-2019, 03:13 PM | #13 |
Re: 2009
I have an 08 with 150K on the 5.3. I have done a lot of towing my 33ft RV around the country. At 115K I turned off AFM because I did not like how it turned on an off with towing but never had an issue with it.
I would opt for 3.73 gears as my 3.42 gears keep the RPM just low enough to bug me towing. I also have the 4 speed and here that the later 6 speed was a good improvement in towing. No experience, only word of mouth. My 4 speed has worked great with a transmission cooler. Also, if you can purchase a truck with the trailer brakes installed on the kick panel it may be better. I always wish mine had that for a cleaner look, but I have heard some people dont like it. I have never ran E85 due to never seeing it at a filling station but over all the truck has been good. The tire pressure sensors usually go out before 10 years but its possible someone could still be running them , they get spendy to replace. I had both the rear window motor cables go out at 8-9 years of age (easy fix). Replaced all the brakes and lines at 8 years of age and new fluid, same with transmission fluid. Mine is an LTZ. I have heard of A/C mixing doors becoming an issue but mine still work and I live in Tucson and use the A/C a lot and never mix in any hot air. I have the cast Iron block and aluminum heads. Not sure if Iron is better or not, I have one broken manifold bolt that I have not repaired, no leaks and I still pass emissions every year. Overall I am happy with the truck and repairs have been at a minimum.
