02-19-2019, 10:29 AM | #1 |
Formerly- 1972SuperCheyenne
Ride height
Hey fellas. So I sold a 2007 Silverado classic a good while ago, it was 2wd and level from the factory. I just purchased a 2004 sierra 2 Wheel Dr. which is significantly lower in the front. I would like it to sit level like the Silverado did. Are there different coil springs? I’d love to use factory stuff not an aftermarket lift kit if possible.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
02-20-2019, 06:49 AM | #2 |
Re: Ride height
Different engine combos had different spring rates. I know my 02 Silverado and 06 Sierrra, both WT models with V6s set lower than my 07 classic Silverado with a 4.8 V8
02-27-2019, 08:47 AM | #3 |
low n' slo
Re: Ride height
ya its annoying. my 02 sits lower in front compared to just about every nbs i get next to. even thought about putting a level spacer up front just to get it up some.
its an ext cab 4.8 v8 2wd
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
06-15-2019, 04:53 PM | #4 |
Re: Ride height
I put 2 inch lift springs on the front of mine. Then tried to put regular dampening shocks rather than Bilsteins. The regular were not long enough. I want to remove the Bilstiens for regular dampening shocks because the w in lift springs are firmer than factory.
2004 Silverado Crewcab (Dark Spiral Gray) |
06-15-2019, 05:03 PM | #5 |
Re: Ride height
Maxtracs
