Stock location - oil pressure sender?
Pros: I am 2 for 2 for "Yeses"
Cons: It is based on "Is my truck wiring butchered?" After rebuilding the carburetor, I realized I need to first fix the engine harness before going forward. I pulled the engine harness today (they had cut a bunch of the wires) and started identifying ones I need to re-wire. One of them is the oil pressure sender. The wire was never hooked up because the sender did not have the same terminals. I am going to buy this (https://www.rockauto.com/en/moreinfo...61884&jsn=1071), but would like to know where the stock location is to install this. I have read somewhere in the rear of the intake manifold. Can someone post a picture on theirs? Thank you.
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
Moderator
![]() Join Date: Oct 2008
Re: Stock location - oil pressure sender?
This differed by year... Assuming it's for the 88 V30
On a TBI engine the large gauge sender is usually on the side of the motor just above the oil filter. The TBI fuel pump oil pressure switch is between the intake manifold and the firewall. If it's sporting a carburetor then the oil pressure sensor could've been just behind the intake or down below. Since you're repairing the wiring you can make it reach the location that makes you happy... I'd install it up top.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
And just for the record. The TBI engine doesn't actually need the fuel pump oil switch. That was just a backup to power the fuel pump in case the fuel pump relay failed.
Thanks Kipps. The truck has been converted over to a crate motor (454) so I will take look about that switch.
At the moment, the oil pressure sender is located in the front on the driver's side just above the oil pan.
#5 | |
Moderator
If he has a carburetor that's a moot point anyway. He has a mechanical fuel pump.
#7 | |
Modern fuel pump relays use a inertia switch or a air bag/computer to kill the fuel pump. TBI uses the oil pressure instead of a inertia switch letting you bounce off trees off road and keep going where a inertia switch will trip and shut you down. The thing can work without the relay once the truck is started and running. But power is run through that switch first then to the relay. This is one of the 10 sensors I replace when I get a tbi truck because if that fails your not going anywhere(unless you bypass it to get home). I have a diagram of the fuel pump circuit with tank selectior that I used to retain this safety feature when running a inline pump/tank. But my image hosting site is messing up so I cant show it to you currently.
1991 Metro commuter 1991 s10 future project truck 1987 V10 backup daily/junk truck 1985 K20 Winter beater 1991 R30(squarebody) c/c flatbed towrig 1994 s10 80"wb custom build |
#8 | |
It's been a couple years now, but I'm pretty sure my '87 was operating quite fine without the oil pressure switch. |
Moderator
The fuel pump, or the fuel pump via the NL2 dual tank power circuit, gets power from three places.
While it will run without the switch you're defeating a safe backup system by omitting the switch. It's not just a backup power supply for the fuel pump. It's backup power with some degree of safety so you can limp home without the fuel pump relay without running the risk of burning the truck down from the fuel pump continually pumping fuel into the fire in an accident. In an accident where the engine stops the fuel pump should stop because the oil pressure drops and the ECM should stop commanding the fuel pump relay because the distributor stops. The OP has a carburetor so he likely has a mechanical fuel pump that stops as soon as the engine stops.
And please let us know if and how your repairs were successful. Last edited by hatzie; 03-19-2019 at 09:32 AM. |
![]() Join Date: Feb 2004
Reviving an ol’ thread,
I’m struggling with my original 88 V30, 454, no start.... fuel issue. Ran great until I filled up at the station and then no start. Bed is lifted, pump replaced even thou the old one worked. Took off the tank selector cover on the frame rail and unplugged the electrical connector, with key on I get about 7.4 volts to only 1 pin. Switching from one tank to another makes no difference. The fuel pump relay on fire wall energizes after about 2 seconds of turning key on. I suspected a bad oil pressure switch behind the distributor but can’t locate it. I only suspect because of reading the service manual. I’m very weak with electrical stuff and schematics. ![]() |
![]() The previous owner put the valve covers on, it’s a stock 454, 22,000 original miles. |
