04-03-2019, 11:07 PM | #1 |
bad power steering affect alternator charging? sbc
I just replace the alternator with a good one
and now sometimes when I start it I hear squealing then whenever I turn on certain things like lights or something it'll be alright it'll be fine and charging properly and then all of a sudden dip down and hear some mild squealing quite a bit is it possible that the power steering pump is messing with the alternator even though they're not directly connected by belt |
04-03-2019, 11:54 PM | #2 |
Re: bad power steering affect alternator charging? sbc
If your power steering pump is not connected to the same belt then I cant think of any reason that it would do anything to the alternator.
Sounds to me that your alternator belt is loose and needs to be tightened.
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1998 chevy c1500 4.3L 5speed (My current driver) 2002 Chevy s10 4.3L auto 4x4 1971 mercury monterey wagon 400 auto To many projects! |
04-07-2019, 09:53 AM | #3 |
X2 if it's not tight it does just what your described.Its not turning it fast enough cause it's slipping on the pulley.Back off the alt bolts slip a flat bar under the alt to keep tension and retighten.Look for right about an 1/8 inch of movement in the belt fully tightened
"Dixie Destroyer" 71 C10 LWB Fleet Future Blown Prostreet Monster |
