Old 04-06-2019, 12:21 AM   #1
Tpo
Junior Member
Modding a C20
I know of a 61 C20 sitting on a farm not far from me. It looks pretty staright from 200 feet away and 40mph. Before I approach the owner, school me a little. Would this be a difficult truck to do the typical stuff to- lower, disc brakes, power steering? Does anyone even make drop spindles for 60-62 C20? I've searched here and found a few modded 64_66 c20s but no knee-knockers.
I guess a broader question is what are the differences between 1\2 and 3\4 ton? I believe they had a thicker frame and trailing arms, different a arms, ball joints, and tie rod ends, bigger axle and drums, and heavier springs. What else?
Thanks!
Tpo is offline   Reply With Quote
Old 04-06-2019, 10:35 AM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Modding a C20
The 60-61 have torsion bar front suspension and the 63-66 are coil. The 60-62 have Eaton HO rear diffs, parts aren’t readily available and expensive,
You could convert to 1/2 ton. They make drop spindles for 60-66 1/2 ton.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-06-2019, 10:41 AM   #3
350TacoZilla
Re: Modding a C20
Up front you could still do the typical 73-87 suspension\crossmember swap just use one from a C20 square body though right? That if he was trying to stay 8 lug I mean.
350TacoZilla is offline   Reply With Quote
Old 04-06-2019, 11:21 AM   #4
Tpo
Junior Member
Re: Modding a C20
To clarify, I don't really have a need or desire to keep the 3\4 ton stuff, like the 8 lugs. It's more just an open question of what to know if I did find a C20 with great sheet metal. Tho I'd feel bad butchering one because someone might be looking specifically for a 20.
Old 04-06-2019, 01:47 PM   #5
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Modding a C20
The rear axle and the front drum stuff isn't worth anything.
If you were to fix it up as a 1/2 ton, you wouldn't be doing any harm.
66 C20 Service Truck:
Old 04-06-2019, 06:29 PM   #6
350TacoZilla
Re: Modding a C20
Yeah if your not looking to keep it 3\4 ton 8 lug stuff then it would be easier to just convert it to 1\2 ton stuff at time of lowering.
