Old 04-16-2019, 03:37 PM   #1
T/C
T/C's Avatar
Wheel question with mix match of parts
So famous words
Building on a budget
Trucks bagged and laying frame i need a pretty crazy offset and i don’t have the money to go buy custom wheels
I have a friend that has a set of the LQ9 17” 8 hole wheels (i have always been a fan) and my wife loves them also.
They use a 14 mm rh 1.5 stud and have a 78.03 hub bore. The offset works great when it’s aired out front and back.
For the rear i am just going to bore out the wheel center to the correct 108mm
My questions are for wheel studs and the front ccp drop spindles.
I can’t find the bore size for the spindles or the lug size.
In the rear i know the lugs are wrong (7/16)
I have seen people post and not mention lug size and saying they bored other late model wheels out to fit the older large bore.
Is there a easy way to convert to the 14 mm rh 1.5 studs? Or will i have to re drill (not a issue)
And on the spindles does anyone know the hub bore and stud size?
Trying to prep for everything to make sure this works.
Input from people who have actually done this would be great.
T/C is offline   Reply With Quote
Old 04-16-2019, 06:51 PM   #2
demian5
demian5's Avatar
Re: Wheel question with mix match of parts
Front are 7/16" I just installed 2 1/2" drops with the 6 lug brake conversion.
But I did use acorn nuts on the transport wheels.
The rears have 1" spacers so those are 1/2" bolted to the drums with 7/16".
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 04-16-2019, 08:37 PM   #3
T/C
T/C's Avatar
Any chance you could get me the hub size on the drop spindles? Guessing it’s 77.80 but just want to make sure
Old 04-17-2019, 10:44 AM   #4
demian5
demian5's Avatar
It has the late model GM Transport wheels on it and they are a snug fit over the hub. So I believe it would be what what your wheels have and will work.
On my 1970 truck, I converted using a different kit (scarebird classics) and it utilizes mid 90's stock heavy half ton rotors with the larger studs. I have the OG steel wheels (4-nib 15x8 6-lug) on there, but had to grind the calipers down a little bit on the ends to clear the wheels. Nice to have more than enough brakes. The 60 isnt in driving condition yet so i can attest to the brakes.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 04-17-2019, 03:16 PM   #5
T/C
T/C's Avatar
Thanks bud!
