Old 04-23-2019, 08:35 AM   #1
landarts
landarts
Transmission help
I finally finished up my long build enough to drive it . The build was over a eight year period. Before I tore the truck down it was a daily driver that ran well and had no mechanical issues, 350 v8 motor with a TH350 transmission. It would from time to time have a small drip or two of transmission fluid as well as engine oil. When I finally got it back together and on the road it leaks transmission oil about 18" x 18" puddle.
Here are the items I noticed after the first drive out of the neighborhood. The truck would not shift out of first gear. Went back home and drained all the transmission fluid and replaced the oil, filter, modulator, also replaced the vacuum line. The truck now shifts into all gears but it shifts really late. It has to get to high rpm's before it will shift. For example where it used to shift around 20 mph now has to go to 35 mph with high rpm's.
So the two problems with the TH350 are it is shifting late and is leaking badly. Does this need to be rebuilt? Is this something a first timer can do? Please advise, and thanks in advance.
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 04-23-2019, 08:42 AM   #2
rjs53
Re: Transmission help
If its the same trans and has been sitting for years, the governor may be sticking. Pull it out and check the springs and weights, see if their gummed up.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 04-23-2019, 09:23 AM   #3
landarts
landarts
Thanks, it is the same transmission that has been sitting over 8 years. I will pull the governor and give it a good cleaning.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 04-23-2019, 09:38 AM   #4
OldBlue70C10
Sometimes the seals will harden when they sit for a long time as well. It may need taking apart and freshening up. You might try some Lucas stop slip, or something like that, and see if the seals will soften back up?
OldBlue70C10 is offline   Reply With Quote
Old 04-29-2019, 11:01 AM   #5
landarts
landarts
Sunday I was able to pull the governor and give it a good cleaning. When I first pulled it out it seemed like the piston inside was not moving up and down freely. So I removed the small pin that holds on the gear at top and cleaned everything real good with brake cleaner and it seemed to help with the piston moving up and down freely. Put it back together and went for a test drive.
The truck shifted the same, it shifted the first time at about 35 mph and the second shift at about 50 mph. When I had the governor out I also inspected the rubber connection at the manifold as well going into the modulator. All rubber was brand new and over the fittings properly. The modulator is also brand new, I do remember the guy at the NAPA counter saying that the modulator was an adjustable type. I guess that will be the last thing I try before looking at a new transmission.
Any other thoughts?
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 04-30-2019, 12:23 AM   #6
Super Dude
Super Dude's Avatar
Yes most aftermarket modulators are adjustable. Remove vacuum hose. Look inside tube where hose goes. If there is a provision for a small flat screwdriver, then its adjustable. Turn the adjuster clockwise for earlier shifts and counterclockwise for later shifts.
1972 Cheyenne Super SWB 2wd 402 Orange & White
1971 Cheyenne 3/4 4wd Black & White
1972 Cheyenne Super 1/2 LWB 2wd 402 Red & White
1968 Chevelle SS 396 L78
Super Dude is offline   Reply With Quote
