Old 04-23-2019, 08:36 AM   #1
Metaltekman
Metaltekman's Avatar
67-72 Gen V LT engine swap mounts
METALTEK MANUFACTURING ENGINE MOUNTS
I would like to share our new Gen V LT engine mounts for the 67-72 c10 trucks
Our engine mounts do require a swap oil pan and use the high hump transmission tunnel. These are item #17050K and the transmission crossmember is #19050A
Thank you,
Jaime
Metaltekman is offline   Reply With Quote
Old 04-23-2019, 03:59 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: 67-72 Gen V LT engine swap mounts
welcome....
nice brackets!
why does the pan need changed? and which pan do you need?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-23-2019, 04:10 PM   #3
Metaltekman
Thanks for the reply, I appreciate it.
The L83/L86 truck pan hits the frame crossmember. For some reason the factory oil pan has a larger than normal front sump area.
I would recommend the Holley 302-20 hands down. It maintains the factory cast rigidity of the OEM pan.
Old 04-30-2019, 12:20 AM   #4
cornerstone
cornerstone's Avatar
Those mounts are the way to go!
I started on my L83 / 72 C10 swap before these were available and realized the problem of the stock truck oilpan hitting the front crossmeber. I cut pretty deep into my crossmember until it did fit, then spent way too much time welding in more steel and boxing it back together to keep it strong. I used the dirty dingo L83 adapters to work with the sbc motor mounts. They wouldn't allow space for the vacuum pump. Plus, The factory oil pan fit, but it still hung down too low for my liking.
Then, frustrated with a pieced together set up, I happened to see the weld in style Metaltek L83 mounts on eBay. These gave me a much cleaner look. I also changed over to the Holley pan and got all the ground clearance I needed.
The point is, save your time and money and buy the new Metaltek motor mounts and transmission crossmember DESIGNED for our trucks. Plus, the other guys making them are nearly 200. bucks more.
Good job Jaime at Metaltek!
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 05-03-2019, 12:07 AM   #5
Metaltekman
Thank you Cornerstone for your review, I appreciate it.
Old 05-04-2019, 12:17 PM   #6
Daaaanz67
Can you give more description on the adjustability if ther is any? Is the drop on the trans cross member lower than the bottom frame rail?
Daaaanz67 is offline   Reply With Quote
Old 05-04-2019, 08:10 PM   #7
Metaltekman
Hello Daaanz67,
The plates that bolt to the engine are slider style. They give you just over an inch of front to back movement. The frame mounting portion of the mounts bolt in to the factory mounting holes.The transmission crossmember is even with the bottom of the frame rail. These mounts with the crossmember are set to the proper driveline angle. These do allow the use either stock manifolds or the Speed Engineering c10 lt headers.
Thank you for your interest,
Jaime
Old 10-09-2019, 10:00 PM   #8
The Pitt
Metaltekman do the speed engineering headers hang below the frame with your mounts?
The Pitt is offline   Reply With Quote
Old 10-14-2019, 11:29 PM   #9
f.flujan
I used tia set up with the headers and they clear just fine. I cupped my lower control arms as well
f.flujan is offline   Reply With Quote
Old 11-11-2019, 10:09 PM   #10
Curt67
Looks good! Does the factory AC and/or Alternator clear?
Can you post some more pics?
Curt67 is offline   Reply With Quote
Old 11-11-2019, 11:53 PM   #11
Curt67
c10 swap, gen v swap, lt engine swap
