Ho52 wheel bearing torque
I looked up the torque in my shop manual page 690 it says to torque the inner nut to 50-60 ft lbs . Then adjust nut backoff 1/8 to align tang on nut lock . Outer nut to 175 ft lbs. But it says this is for barrel roller bearings . Mine looks to have been replaced with tapered bearings. I can't see going that tight on a tapered bearing. Any advise as to proper torque or do I do it like the fronts . Tighten to drag then back off to lock in.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 04-30-2019 at 05:32 PM. |
All about them K’s
![]() Join Date: Jun 2014
Re: Ho52 wheel bearing torque
The 10.5” floating 14 bolt uses tapered bearings and you torque them to 50 then back them off and set the lock washer like above. The outer Then gets 100 if I remember right. I don’t think 50-60 is too much personally. If your talking about the outer nut I’d do what the manual says there.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Thanks guess I'll do it as per the manual
![]() Join Date: Mar 2019
off the subject but where do you get this so called manual? I'm sure LCM has it or Brothers, any alternatives?
#5 | |
![]() Join Date: May 2010
http://67-72chevytrucks.com/vboard/s...ghlight=hatzie Most torque values are listed by manual section at the end of the manuals. |
