Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 05-01-2019, 03:30 PM   #1
charlesfeild
2000 Sonoma blower mot0r
blower motor just stopped working, anyone know what fuse to replace or how to fix it? thanks
charlesfeild is offline   Reply With Quote
Old 05-18-2019, 10:49 PM   #2
CastIron
CastIron's Avatar
Re: 2000 Sonoma blower mot0r
if it failed on just one or two speeds, it probably needs a resistor and a motor. Check for voltage at the blower motor connector with the fan turned on. If it has power and ground, it probably just needs a motor.
The motor isn't terribly difficult to replace. It's easiest to just lower the fender liner so you can pull the blower cage out of the box without have to remove the ecm and coolant reservoir. It may have a cover you have to cut to get to the blower though.
CastIron is offline   Reply With Quote
