05-04-2019, 12:37 AM | #1 |
What tyre size is recommened to run on a 64 - 66 chevy c10 ?
Just like the title says, what is the recommend size to run without having any issue(s) on rubbing or turning ? Was looking for stock steelies ( still running drums but plan for disc upgrade later on ) but seems i ll be running 4x4 rallies from a blazer ( 6 lug wheel ) ....
dont want to hear excuses, i want to hear solution(s) |
05-04-2019, 12:38 AM | #2 |
Re: What tyre size is recommened to run on a 64 - 66 chevy c10 ?
Those rallies are 15 inch
05-04-2019, 05:05 AM | #3 |
On my 62 drums, 6 lug. Running 255/60 15 front 275/60 15īs back no problem gives a good stance I think. 7" rims
05-04-2019, 01:20 PM | #4 |
I have 255/70 r15s all around on 15x8 truck rallies. Stock height with no problems at all.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
05-04-2019, 06:50 PM | #5 |
1965 Chevy C10, 2005 4.8L/4l60
I run 15 Ralleys with 7 up front and 8 in rear.
Front: 235/70/15 Rear: 275/60/15
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
05-04-2019, 06:59 PM | #6 |
Moderator
05-05-2019, 12:32 AM | #7 |
My main issues are tyres hitting ( turning radius in the front )or rubbing ( clearance in the rear in the fender well/ tub ) .
