05-08-2019, 06:59 PM | #1 |
Repair or replace radiator?
I bought this Champion aluminum radiator and less than a year later, it started leaking. I added 2 bottles of stop leak and that worked for a short time and now it's leaking worse than ever. It's leaking where the tubes and tank meet on both sides.
Can this be repaired? If not, what kind of radiator do you recommend that won't break the bank?
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
05-09-2019, 02:41 AM | #2 |
Re: Repair or replace radiator?
I’m very happy with my spectra radiator. Was like $110 and truck runs cooler than my stock BB radiator did.
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
05-09-2019, 03:32 AM | #3 |
Post Whore
I got mine from oreillys for around $100...been about 10yrs and still going strong
05-09-2019, 04:08 AM | #4 |
I have used Champion rads for years,never saw one like that,make sure when you buy anti-freeze, that is compatible for aluminum rads,i heard that if you use the old style green stuff,that it will eat it up.
05-09-2019, 07:59 AM | #5 |
Less then a year? Check your warranty period. Possible you got a 'Monday' radiator.
05-09-2019, 04:45 PM | #6 |
Spretre are plastic tank and aluminum core.
Pony up that $500 for a 4-row AC big block Brass and copper. Those last for ever.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
05-09-2019, 06:39 PM | #7 |
This is usually why I like Genuine Radiators. If you can find one
Never bought an Aftermarket so I wouldn't know. But My guess is maybe just a Faulty Radiator, should be able to get a new one under your Warranty.
1979 Pontiac LeMans 231/Th350 1982 Chevrolet Silverado K10 6.2 Diesel/700r4 1984 Buick Regal Limited Sedan 4.3 V6 Diesel/200r4 (Hens teeth rare) 1991 Chevrolet Silverado K2500 5.7/700r4 1999 Chevrolet Base LS K2500 6.5TD/4L80e |
05-18-2019, 09:52 AM | #8 |
Update:
Champion Radiator did honor the lifetime warranty without question. The new radiator arrived in 3 days and is now installed. I hope that the previous one was just a bad one and this one lasts for the life of the vehicle.
05-18-2019, 11:02 AM | #9 |
I've had a champion in my 1950 F1 for seven years now with no issues.
Like everything, every once in a while things go wrong.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
05-20-2019, 09:32 PM | #10 |
I am here now also. My 3 row frostbite doesn't agree with the stock 3 row mounts. Gotta send it back to Jegs.
