![]() Join Date: Dec 2014
Flip Kit Shock Options
My parts hoarding and collecting has reached the point where I can finally make some big changes to my 81 swb stepside. I have ECE lowering spindles and coils for the front, and a Belltech flip kit for the back. I'm going for a 4/6 drop and I have never done anything like this before. Incidentally the ECE guys are phenomenal to deal with: I wish I had gone with them for the rear as well.
I have learned from the forum that when installing the flip kit I will need to either install shock relocators, or get a shorter shock. Normally I would just get the shock relocators, but I think I need new shocks anyway: I am thinking of foregoing the relocators and buying shorter shocks. Anyone gone this route instead? If I do this, what shock should I buy: I know nothing about buying shocks unless they are the stock ones that the parts guy hands out by request.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
Re: Flip Kit Shock Options
I bought the belltech BT2208HF for the rear of mine. I also have just the flip kit and bolt in c notch.
Did you relocate your shocks, or go with a shorter replacement?
driving is in my blood
You don't relocate anything you merely bolt on extenders to the factory shock bracket so the shock mounts lower and has the same overall travel as before.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
Extenders! Yes, that is what I meant. I understand that they are not particularly expensive, I will look into those. Was wondering though if I need shocks anyway, do I just buy shorter shocks, instead of new shocks and new extenders. Thanks for your input.
I'm not convinced that companies make "lowered shocks". They simply use another application and charge you more. After a little research, I discovered KYB 344055 for Toyotas and Nissans will work for the rear with a flip. The only catch is that the lower bushing for those shocks use a 12mm bolt, and our squarebodies use a 7/16" bolt. So, you will have to drill out the mounts to 12mm OR be able to re-use the old bushing.
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30 |
They are basically just shorter with more damping. Having used several sets of shocks on the front of my lowered trucks, I can say for sure there is a difference.
OP- Look at doestch tech. They have been the best for me overall. I haven't used them in the rear as I always get extenders but up front they out perform everything else.
longer shocks with extenders made a noticeable improvement to my ride quality
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
Having looked into it I am seeing a lot of stuff about how Belltech designs the kit so it won't accept extenders, they want you to buy their shocks. Since I need some anyway I picked them up, they are for a 4-6 inch drop. I didn't think I would be so easily manipulated by a corporation, but apparently I am.
I'm discovering how fun it is right now to try to remove 40 year old shackle bolts. Of course the one by the gas tank won't budge and I'm too cautious to get out a torch or grinder because of where it is.
Go with the extenders. You can use your old shocks if they are in good shape, it keeps a better shock angle and you won’t limit the travel of the rear(compression and droop) with shorter shocks.
53 GMC COE stock 53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949 '70 Chevy C10 LWB 350/sm465 74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
#11 | |
Plus the shock angles are better which helps with dampening through the magic of math, and angular stuff. I don't really understand |
Extenders an stock replacement shocks are the way to go. I prefer KYB as to me they seem to give the best ride.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
#13 |
I put the Nitro drop shocks with a flip kit on my stepside. I will be changing over to extenders and the KYB's. When you see the angle of the drop shocks it just doesn't look right. I am also experiencing a bit of wheel hop. Not sure if they have anything at all to do with that though.
