05-12-2019, 12:53 PM | #1 |
fuel tank selector switch?
Based on Hatzie's write-up, the 73-80 trucks used a 5-pin DPDT switch. Hatzie mentioned that some switches you buy would potentially include the sixth pin, but it needs to be removed for a stock application.
I would like to use that switch in a non-stock situation, and want all six pins. Does anyone know of a DPDT rocker switch that will fit right into these trucks that is a full six-pin DPDT?
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
05-14-2019, 02:21 AM | #2 |
Moderator
Re: fuel tank selector switch?
Do you have a rectangular hole in the dash already?
If you're retrofitting I'd use a toggle switch. A 1/2" round hole is easier to make than a rectangular hole that's properly aligned with the dash.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
05-14-2019, 05:45 PM | #3 |
I already have the factory switch hole in the dash.
It appears the switch from a Ford OBS truck will do exactly what I want. I may have to reshape the hole a little.
