What is the paint code for this?
In the process of looking for paint to see what is available. Would like to go with lacquer or at least a single stage. Not the least bit interested in base/clear. Anyone know what this paint color is called or a code? Haven't found anything that looks right but this is a very common color on these pickups in Idaho
Moderator
![]() ![]() Join Date: Aug 2011
Re: What is the paint code for this?
Could be 1964 (since I dont know) GMC (guessing) Light Blue, Paint code 507, GM Code WE5120, Dupont codes: 4537L, 4537, 93-78387.
I think its called Terrace Blue
Moderator
This should help confuse things
I appreciate the info, I'll keep doing a little research and see if I can get something that will match
![]() ![]() Join Date: Apr 2012
This is Terrace Blue GMC number 509 WE5126 kind of a blue green color . Original exterior paint on these trucks was enamel , not lacquer .
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
