Source for Cylinder Head bolts for 292?
Would like to replace my cylinder head bolts on my 66 292, but cannot find a source anywhere? Are these even available? I'd prefer not to use ARP studs (for cost and appearance) and I'd prefer to not reuse my original bolts.
Thanks! |
Re: Source for Cylinder Head bolts for 292?
HeadBolts.com
Thanks Suville, I saw that, but out of stock, no ETA when they will become available again.
Who Changed This?
![]() Join Date: Jan 2013
As long as the threads in the block and the bolts are still good, those bolts can be reused. It's only those late models that require the torque and then an extra bit of a turn that can't always be reused, because they have been stretched. What is your concern?
#5 | |
Who Changed This?
Bummer. The threads in the block may need heli-coils, then. Something to consider.
Never Ending Projects
When I rebuilt my 250, I used ARB head studs, which are much better than head bolts. Got them from Summit Racing.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
And they have better clamping power so you are less likely to ever have a head gasket failure. They also claim to make the block stronger is a few key areas that are prone to cracking.
Give your local Chevrolet dealer a try. If they are not in stock they can usually get them from a central warehouse in a few days. I've gotten parts from Chevy for old cars a bunch of times.
Update: Got all the bolts out and they all look great, sitting in rusty cooling jackets for 25 years didn't appear to hurt them. Thankfully. Thanks for all the responses!
