06-02-2019, 08:43 PM | #1 |
LS Wire Harness Length?
Does anyone know if a stock ls harness from a truck will be able to mount the computer under the dash? Or do I have to extend it? If so by how much?
1986 Chevy Fleetside Wrangler (Canadian Only) |
06-02-2019, 08:52 PM | #2 |
Post Whore
Re: LS Wire Harness Length?
Should be plenty long..maybe to long unless you shorten it...
06-04-2019, 03:29 PM | #3 |
The factory harness runs off the top of the intake manifold to the drivers side fender well. I would be willing to but it won’t be long enough without a serious amount of modding to the harness.
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
06-04-2019, 08:50 PM | #4 | |
To answer your question about how much to lengthen the wires. If you leave the bulk of the harness as-is, and just turn the main pigtail of wires toward the firewall, I'd guess you need at least two more feet to get the ECM into an out of the way place in the dash. That would be minimum, but I haven't actually measured. I'm simply putting my fusebox and ECM on the inner fender, where it's supposed to be.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
