06-03-2019, 09:45 PM | #1 |
Detailed my 235 what you guys think?
This is my 62’ replacement block.
Painted it and detailed it. I have more work today such as decals on the valve cover and some misc. |
06-03-2019, 10:27 PM | #2 |
Re: Detailed my 235 what you guys think?
Did the lettering and numbers as well
06-03-2019, 10:57 PM | #3 |
nice job looks great
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
06-03-2019, 11:56 PM | #4 |
06-04-2019, 01:01 AM | #5 |
that s going to sound as good as it looks
06-04-2019, 07:53 AM | #6 |
Moderator
That's pretty cool right there.
06-04-2019, 09:23 AM | #7 |
I love an original looking classic motor. Many of the chrome bling parts are nothing more than imported junk anyhow. Looks great!
06-04-2019, 09:45 AM | #8 |
Looks terrific!
06-04-2019, 10:36 AM | #9 |
1965 Chevy C10, 2005 4.8L/4l60
Great job!!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
06-05-2019, 11:50 AM | #10 |
It's Better With Nitro
That's awesome! Great job!
06-05-2019, 03:37 PM | #11 |
Nice!
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1978 chevy c20 350 4speed 1998 chevy c1500 4.3L 5speed 2002 Chevy s10 4.3L auto 4x4 Plus a Mercury & some Fords... To many projects! |
06-06-2019, 09:47 PM | #12 |
Looks great.
06-12-2019, 11:53 AM | #13 |
Thank you everyone!! Been taking my time on this one!!
I do have a question about getting a good seal on the valve cover. I know there is info on this forum and online but I am stumped. I can’t ever get my valve cover to stop leaking. I’ve already straighten it as good as possible and flatten the holes. But it still leaks at certain spots. I tried just silicon on the cover side/dry on head. Leaks BAD. I’ve tried silicon in both sides, and minimum spots. I’ve tried a lot of silicon and tried a little bit. But can’t get it to stay leak proof no matter what. Tighten the screws down hand tight, I have the spread washer on as well Does anyone know any good tricks with these old 6’s or is this just another common character to these motors? Here is another update, I just put on this period correct decal. I got a extra 5hp boots. Lol Last edited by Isaiah92260; 06-12-2019 at 12:05 PM. |
06-12-2019, 11:59 AM | #14 |
Excellent Job!!!!
06-12-2019, 12:11 PM | #15 |
Not sure about your the particulars of your exact engine but Permatex Right Stuff works very well when I have used it. Much better than Ultrablack Permatex. It costs twice as much and comes in a cheese whiz type can. You don't have to wait 24 hours for it to dry and test it either, only about 5 minutes.
06-12-2019, 12:40 PM | #16 |
Same problem on my old 53. I wound up using to cork gaskets. I mounted them dry .it worked for me.
06-12-2019, 01:49 PM | #17 | |
Do you use it by itself or with a cork gasket put it on both sides or just on the valve cover side? |
06-12-2019, 01:51 PM | #18 |
06-12-2019, 05:57 PM | #19 |
Have you used the valve cover hold downs?
06-12-2019, 06:23 PM | #20 |
Sorry my post should have read..I wound up using 2 cork gaskets
06-12-2019, 06:32 PM | #21 |
06-12-2019, 06:36 PM | #22 |
06-12-2019, 08:52 PM | #23 |
No just dry hopefully it works for you
06-13-2019, 07:32 AM | #24 |
I had to double cork my 1961 Cadillac. The cork thickness isn't what it was back in the day. Single isn't enough. I did use silicone on the outer surfaces and not in between the gaskets. Haven't had a leak in 5 years.
--Life looks better through a curved windshield-- |
