06-04-2019, 11:54 AM | #1 |
Stock and drop formula, wheel vintiques?
So according the Squarebody syndicate formula on their website they suggest you custom order the 62 series steels wheels from Wheel Vintiques. Front wheels 15x8 with a 4" backspace and the rears 15x10 with a 5" backspace.
I called Wheel Vintiques yesterday to order these wheels with the custom backspace. They said that they can only do the 15x8 in 4 1/4" backspace and NOT the 4". They did mention that if I ordered the wheel inverse (flipped around) that only then they could get the backspace to 4". But that would give a slightly different lip appearance. My question is what kind of fitment issues would I have if I ordered the 4 1/4" backspace on the 15x8 (front wheels)? Is there any other company that makes the O.E looking steels wheels that I can custom order the backspace and still be able to install the poverty caps/dog dishes. thank you for your time. |
06-04-2019, 02:01 PM | #2 |
Re: Stock and drop formula, wheel vintiques?
The 4.25" BS will work as well. There could be a possible interference issue @ the lower control arm when using some drop spindles. It's a simple (& common) fix that requires trimming the lip back (also referred as 'trimming the rain gutter') between the BJ & shock mount tab area.
Also, ordering a 'custom' back space is (was?) $25 extra per wheel.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-04-2019 at 02:10 PM. |
06-04-2019, 02:24 PM | #3 | |
Hey thanks man! Yes its 25 extra per wheel but the guy said they couldn't make it with the 4" backspace. The lowest he would go is 4.25". I guess I'll just order them anyways. Thanks |
06-04-2019, 02:27 PM | #4 |
They'll work fine. Just check for the clearance issue mentioned (usually occurs near full lock/turn) & tweak the a-arms if necessary.
06-04-2019, 03:25 PM | #5 |
When I ordered Wheel Vintiques Wheels the price was cheaper through Summit racing then it was through Wheel Vintiques. That was a few years ago but it worth be worth checking. Summit also has free shipping on orders above $99.00.
https://www.summitracing.com/search/...cending&page=1
It only has original paint once |
06-04-2019, 04:30 PM | #6 | |
06-05-2019, 10:18 AM | #7 |
Since your in Tacoma phone the old car center in Van.B.C. They sell WV but they told me of another place in Ca. not stockton wheel but another that I can,t remember. They said people were getting PO at the wait time from WV
06-05-2019, 01:02 PM | #8 | |
https://thewheelsmith.net/wheel-catalog |
06-05-2019, 01:29 PM | #9 | |
At any rate, I am sure that 4.25 is fine.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
06-05-2019, 06:29 PM | #10 | |
Yup, I just called these guys and they made me the ones I want! The Wheel Smith FTW! Thanks |
