Rear wheel cylinder removal.
I'm in the process of redoing the rear brakes on my 63. New shoes Hardware wheel cylinders etc. Passenger side cylinder came off no problem but when I try to disconnect the fluid line the fitting won't release the tubing and wants to twist. Does anyone know of a way/trick to stop this from happening?
Thanks in advance Charles |
Re: Rear wheel cylinder removal.
Change of topic now. Does anyone know what size line I need to buy to replace the broken one to the drivers side wheel cylinder?
Thanks. |
60-66 Nut
![]() ![]() Join Date: Mar 2007
That should be 3/16" tube.
Most parts houses for these trucks sell the left and rights in a pair. Not a bad idea to just replace both.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
![]() Join Date: Sep 2002
Depending on how correct you want the the finished product your local parts store can match it up. It will always be too long so that might be an issue to you.
You could cut the line and reflare it with a typical double flaring tool. They don't clamp the larger lines very well but if you get a decent one 3/16" should flare OK. |
