CPP 73-87 brake booster combo question
hey all, i have an 86 1/2 ton. i want to replace the brake booster/MC/PV on my truck because i switched from the JB3 code to JB5 code hardware (drums/rotors/calipers/wheel cylinders)
my question is. will this CPP combo work for my truck? cpp part number 7387BB-MC https://www.summitracing.com/parts/clp-7387bb-mc called their tech line, they said it is an 11 inch single diaphragm... or should i just buy the factory parts?
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
#2 | |
Re: CPP 73-87 brake booster combo question
It will likely work, but you may have to adjust the pushrod in the booster, otherwise your pedal may be soft when the engine is running.
#4 | |
since this is aftermarket, i was looking for some feedback from someone who has used in this scenario..., if this one, being a single diaphragm, is it equal to a dual as far as power is concerned?
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy Last edited by naphtali5725; 06-15-2019 at 02:28 PM. Reason: grammar |
went ahead and ordered factory replacement BB and MC from rockauto
Good luck, and dont forget to bleed the master cylinder too.
BEFORE you install it in the truck.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
do NOT bench bleed them with the stupid plugs they give you now a days . get a hose kit or make your own from 2 hard lines and a extra set of hard line nuts .
i did one with the plugs and it never felt right clamped in the bench vise using a long screw driver to plung it . took them out and did the hard lines i had ( had to go looking for them ) and the unit belched so much air it wasnt funny . felt super after this . installed and bleed system good to go .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
#9 | |
just dont use the solid cap plugs . most any hose kit or if you do a few more than the average guy then i like hard line .
