Old 06-22-2019, 11:57 AM   #1
Afirehawk1
66 C10 Stepside Bumper Brackets
I have a set of bumper brackets.
So which is front and rear?
For chrome bumper setup.
Afirehawk1 is offline   Reply With Quote
Old 06-22-2019, 04:15 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 66 C10 Stepside Bumper Brackets
The middle pic. Here is a link - http://67-72chevytrucks.com/vboard/s....php?p=8392706
Old 06-24-2019, 09:44 AM   #3
Afirehawk1
I had the longer ones in the front and they stick way out beyond where the 2 center frame supports are located. i am confused now.
Old 06-25-2019, 02:24 PM   #4
Heater63
Heater63's Avatar
the top picture are the rear bumper. the longer bracket with 4 holes has a relief to clear the rear bed mounting bolts. They only will go in and fit one way.
I have recently seen one thread on here that shows pictures of the rear brackets.
What is the length on the brackets in the bottom picture?
292 + TKO500
Heater63 is offline   Reply With Quote
Old 07-03-2019, 09:27 AM   #5
Afirehawk1
The length of the front brackets are 22.5 inches
Possibly i mounted to wrong bolt hole on the frame??
Old 07-04-2019, 10:57 PM   #6
Afirehawk1
Can someone confirm where these bolt to the frame?
Which bolt holes?
Old 07-05-2019, 09:41 AM   #7
Vinceg
Vinceg's Avatar
Sorry for the poor pic’s. I hope it gives you a bit of an idea. Im pretty sure I loosely bolted it onto the bumper and rotated the bracket up to the hole. If you have installed power steering you will have to trim the top corner of the bracket so it will fit.
Vinceg is offline   Reply With Quote
Old 07-07-2019, 08:42 AM   #8
Afirehawk1
Thanks for the pixs!
