Old 06-22-2019, 04:18 PM   #1
earl84
Brake line coil off master cylinder necessary?
I am redoing all my brake lines in conjunction with adding a Wilwood master and proportioning valve. Question is whether or not the coils are necessary or not that are generally right off the master.
I know GM did it on most stock trucks, but I see a lot of trucks without them. I want to do some different routing to clean things up a bit while I’m at it, and don’t really want to do the coils. If they are necessary, I assume thy should be horizontal instead of vertical so air can’t get trapped in the top part of the coil.
earl84 is offline   Reply With Quote
Old 06-22-2019, 04:22 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Brake line coil off master cylinder necessary?
The coils allow for flex between the body and frame...I used -3an ss hoses on mine to eliminate the coils..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-22-2019, 09:10 PM   #3
earl84
Thanks for the reply. I think I am going to stay with the double flare 3/16 line. Broke the freakin’ double flare die today, so I am on hold anyway. I see so many clean lines run, like TheSub, OMGosh, that engine bay is insanely clean. Mine is nowhere near that, nor will it ever be, but I try to clean things up as I go.
Old 06-22-2019, 09:16 PM   #4
mongocanfly
Post Whore
those fittings I used are double flare to -an....nothing wrong with using the coils though
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-22-2019, 10:13 PM   #5
damnyankee36
damnyankee36's Avatar
I don't know how the trucks were assembled but for Camaros the master cylinder was attached to the brake lines and left unsupported when the subframe was assembled. Only the two brakes lines held it up. The coils allowed for movement of the master cylinder without damaging them. When the subframe was attached to the body it was then bolted to the firewall or booster.
So, to answer your question, I would say it's not absolutely necessary to include the coils. There is negligible movement between the body and frame. I believe a little bit of slack in the lines wouldn't hurt however, mostly to make it easier to connect or disconnect the lines at the master cylinder.
damnyankee36 is offline   Reply With Quote
Old 06-23-2019, 06:11 AM   #6
The Rocknrod
Moderator
The Rocknrod's Avatar
Not needed.
Old 06-23-2019, 08:11 AM   #7
Keith Seymore
Keith Seymore's Avatar
Originally Posted by damnyankee36 View Post
I don't know how the trucks were assembled...
Trucks used a temporary master cylinder "slave" bracket on the chassis line to support the assembled system until it was attached to the front of dash. The slave bracket was then removed and recycled back to the installation point to be reused.
The brake system is completely evacuated, filled and function tested by this point.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 06-23-2019, 08:19 AM   #8
damnyankee36
Originally Posted by The Rocknrod View Post
Not needed.
Hey Chief. Off topic but I think your'e gonna like the 11" booster. Mine is a 9" and I have to stand on pedal a little too much for my liking. That's what was offered from CPP so I didn't question the size.
Old 06-23-2019, 10:44 AM   #9
The Rocknrod
Moderator
That's a bummer for me. I just bought a 9" chrome unit. Maybe I should sell it and get a 11" in chrome one.
I was thinking about going all chrome instead of all Yellow zinc in the engine compartment...
Old 06-23-2019, 11:49 AM   #10
Chevy Fleetside
Chevy Fleetside's Avatar
I have been running like this for 2 years now. I used a coupler so I could use my original brake rod with the later model power booster. There is a locking nut on there, you just can't see it.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 06-24-2019, 11:14 AM   #11
demian5
demian5's Avatar
Its a non issue, makes for easier mast cylinder replacement though...
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 06-25-2019, 01:08 PM   #12
dracko
dracko's Avatar
No coils and no issues so far.
dracko is offline   Reply With Quote
Old 06-27-2019, 01:47 AM   #13
1966 K10
1966 K10's Avatar
Looks clean. What year MC did you use? No warning switch or proportioning valve?
1966 K10 is offline   Reply With Quote
Old 06-27-2019, 02:42 AM   #14
bloo
As others have mentioned, the coils are there to take up motion between the body and frame. Yes, you can get by without, just pay attention to the motion. See how in The Rocknrod and dracko's pictures the lines go way over toward the driver's side and come back? It spreads the motion out over a whole bunch of line. That is more or less what the coils do.
Here's a disc brake conversion done in the 80s:
bloo is offline   Reply With Quote
Old 06-27-2019, 10:08 AM   #15
dracko
dracko's Avatar
I think its for a ‘71 non-power disc/drum c10. I used an early 80’s prop valve with warning light switch, mounted under the fan shroud like the square bodies.
Old 06-29-2019, 12:21 PM   #16
sodly
sodly's Avatar
I was curious about that master cylinder, too. Do you happen to know the exact brand/model? I like how it's more square and looks more like the old, pre-60s style/shape. Seems smaller than the later style too. It's a little less obviously out of place that most. Wondering where you found that one. Thx.
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline   Reply With Quote
Old 06-29-2019, 12:25 PM   #17
The Rocknrod
Moderator
Are you going Disc/Drum? or 4 wheel disc?
Old 06-29-2019, 12:27 PM   #18
Warrens69GMC
Warrens69GMC's Avatar
That master is like this one at AutoZone
NM1494
https://www.autozone.com/brakes-and-...03_0_2558_2867
Old 06-29-2019, 12:39 PM   #19
The Rocknrod
Moderator
If your dyslexic.
Old 06-29-2019, 01:59 PM   #20
bloo
Yeah, the rear brake reservoir is in front.
It looks like the same casting as the one I posted. The fittings are appear to be a different size though. IIRC it was for a mid 70s Ford van or truck (1978 econoline?). Disc/drum, 1-1/8" bore.
Old 06-29-2019, 02:14 PM   #21
dracko
dracko's Avatar
I got it from rock auto. Raybestos MC39177
Old 06-30-2019, 11:43 AM   #22
rvrfoot
cpp on mine.Name:  DSCN0824.jpg
rvrfoot is offline   Reply With Quote
Old 06-30-2019, 12:57 PM   #23
The Rocknrod
Moderator
That's sweet right there.
Old 06-30-2019, 02:18 PM   #24
damnyankee36
I went as far to as to recreate the factory coils.
Lots of ways to go about this...
Old 07-06-2019, 04:49 PM   #25
Mike_The_Grad
Mike_The_Grad's Avatar
On my dads 1964 c10 292 inline 6 with all drums and no power assist, the replacement brake line kit I got from classic industries did not coil the line right out if the master. Instead they put sort of saw toothed pattern in the line. Like triangular shaped. It seems to do the same job as the coils by allowing some flexibility in the line according to master cylinder position. I was able to just press the line down a little to get it to line up with the port on the master.
1972 C/10 LWB - Mine
1964 C/10 LWB - My Dad's
Instagram: Mike_The_Grad
Mike_The_Grad is offline   Reply With Quote
