Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 73-87
Old 06-23-2019, 07:33 AM   #1
cfan10
cfan10's Avatar
Cool Bad ICM the culprit?
I've been tinkering with the c10 mechanical side, timing, new battery. I tried to start it the other day, kept cranking but wouldn't start.
I redid the timing bringing it to tdc, pulled the distributor put a coil I had laying around, tried that one and smelled something like burnt plastic. Took it out, put the other coil back in installed a brand new icm I had for a few years, now I turn the key everything works cluster, headlights, electric fuel pump but try to start and nothing. I dropped the starter tested it with a battery works fine. Can an icm be brand new and not function, I did use heat sink compound on distributor base and icm.
Anyway to test an icm out of the vehicle, checked the pick up coil when I had the distributor out its intact.
I also bottle tested the fuel pump and it half filled a 2 liter bottle in a short time.
'84 c10 350 hei street fire distributior and 3 years old but was working fine a few months ago.
As always thanks in advance for your time and advice it is greatly appreciated!
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me.
Don't mess with my truck, my momma or my money...not necessarily in that order. ©
Stand for something or fall for anything.
[LIST][*]'98 Bourbon St. Brawl ©2010
cfan10 is offline   Reply With Quote
