07-07-2019, 11:54 PM | #1 |
Is this rear stock?
Can someone please tell me if this rear end is stock for a 62 c10? I’m looking at putting 2” drop coils and 2” drop blocks but dont want to get started if im not sure what I’ve dealing with. I know the air shocks are not stock. But with that being said do you need both coils and shocks? Thanks
07-08-2019, 04:03 AM | #2 |
Re: Is this rear stock?
This rear end is not original for a '62. This is a 12 bolt from '65 and later. But that's no problem when you want to install dropcoils.
07-08-2019, 10:16 AM | #3 |
The 62 had longer panhard bar mounted to axle tube. And was a round pumpkin. The arm mounts would be wider than the mounts that are stock to rear or leaf.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
07-08-2019, 12:01 PM | #4 |
The u-bolt setup looks.... strange.
The u-bolts are supposed to go through the center of the trailing arm. I know the 60-62 trailing arms are spaced wider, which is probably why there's another U-bolt on either side. Looks like there is some sort of adapter plate there to fit the later axle.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
07-08-2019, 12:05 PM | #5 |
07-08-2019, 02:55 PM | #6 | |
Good Luck |
07-08-2019, 06:42 PM | #7 | |
But Found Her 25yrs Later!
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
07-08-2019, 11:11 PM | #8 |
60-66 Nut
The first thing I would do is remove that whole cobbled mess with the u-bolts and shims.Then weld on some new trailing arm mounts in the correct location for your trailing arms. Then you can change the springs and add your drop blocks. The springs and blocks for a '62 are no different than for a '65. You will want the dropped panhard bar assembly for a '60-'62.
07-10-2019, 07:25 PM | #9 | |
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
07-11-2019, 06:43 PM | #10 |
Thanks for the input. Luckily for me I’m very very limited in my knowledge of this stuff. So I think I may need to find a shop to do it. Any one in SoCal know of a good shop to use?
