Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 07-16-2019, 10:38 PM   #1
colgad
colgad's Avatar
67 C50 Exterior door handles
I am replacing the door handles on my 67 C50 and the new door handles are not drilled the same. The originals are drilled straight and the new ones are drilled at an angle.
Has anyone else seen this? Are all C50's this way?
thanks
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 07-17-2019, 08:11 AM   #2
CarolinaHD
Moderator
CarolinaHD's Avatar
Re: 67 C50 Exterior door handles
Its 67 vs 68-72 thing, you'll need 67 year specific handles. C50 use the same door handles as the small trucks of the same year.
Alex
1967 C50 292ci Lumber truck
1967 C50 292ci Dump truck
1967 C60 366ci Fire truck
CarolinaHD is offline   Reply With Quote
Old 07-17-2019, 10:55 PM   #3
colgad
colgad's Avatar
When I look up door handles they all say 67-72, no separate 67 handles.
Old 07-17-2019, 11:00 PM   #4
CarolinaHD
Moderator
CarolinaHD's Avatar
They're all wrong, your only options are a used handle from a 1967 only or modify what you have to fit
http://67-72chevytrucks.com/vboard/s...d.php?t=722748
The difference in handles (and doors) is----- in the handle, the screw (bolt) hole is at an angle compared to the contact face of the handle.
In the door--- the mounting holes in the door are horizontal and the re-inforcement inside the door is vertical (because the mounting screws are supposed to go thru the door and into the handle Horizontally.
in 68-72 doors the mounting holes in the door are slightly offset because the screws go thru the door at aprox. a 15 deg. angle.
You can elongate the door holes-----but, the mounting re-inforcement on the inside of the door is still vertical-----which means as you tighten the bolt it wants to rotate the handle downward.
You need an angled pad for the screw to tighten against, As well as elongating the holes.
As I mentioned, its not a major job----but I'm having a problem believing that none of the parts suppliers either know it or are remotely interested in the fact that they wont fit.
I searched far and wide for perfect doors and due to the fact that the doors are already painted I really don't want to screw with them.
Alex
Old 07-20-2019, 11:17 PM   #5
colgad
colgad's Avatar
Thanks for all the input, since I do have the old pitted handles I find a place that can rechrome them. Weird that it was a big truck only thing. My 67 C10 doors were normal.
Thanks again!
Old 07-20-2019, 11:24 PM   #6
colgad
colgad's Avatar
This is before I started taking it apart again to paint it.
Old 07-21-2019, 10:10 AM   #7
CarolinaHD
Moderator
CarolinaHD's Avatar
Dang that looks good! Cant wait to see it finished
Alex
Old 07-24-2019, 09:22 PM   #8
colgad
colgad's Avatar
Thanks bud!
Old 07-28-2019, 01:10 PM   #9
jerry.t
chip foose has a 67 build video on youtube. he addresses this issue and shows the fix
jerry.t is offline   Reply With Quote
Old 07-28-2019, 01:13 PM   #10
jerry.t
https://www.youtube.com/watch?v=-4rdnfTlWqA watch this video
Old 08-01-2019, 12:15 AM   #11
colgad
colgad's Avatar
Originally Posted by jerry.t View Post
THANKS! that is a great idea!!! To as Foose said a simple fix.
thanks again bud!
