07-20-2019, 01:52 AM | #1 |
No spark, new junk
OK, back again with more misadventures...truck was getting no power to the distributor and there was that weird melting plastic smell. So I replaced it with an cheap clear assault racing one. New battery tested on other vehicles and they seem to run fine.
Took the starter down tested it on a battery seems to work fine battery cables are in good shape. When I turn the key to the accessory position the fuel pump runs and fills the filter with gas, but when I turn to the start position the fuel pump gets no power nor does anything else. Getting no power at distributor tried a spark tester. Hot coming off of the fuel pump goes into choke on fuse block under dash, checked all fuses none are blown. '84 c10 350/350 hei distributor Mr. Gasket electric inline fuel pump. As always many thanks for your advice, it is greatly appreciated.
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me. Don't mess with my truck, my momma or my money...not necessarily in that order. ©Stand for something or fall for anything. [LIST][*]'98 Bourbon St. Brawl ©2010
07-20-2019, 02:43 AM | #2 |
Post Whore
Re: No spark, new junk
I know nothing about the newer Gen IIIs so don't laugh at me, but could it be the Neutral Safety switch, can you bypass that monkey
07-23-2019, 09:52 AM | #3 |
Moderator
Have you checked the ignition switch and the Neutral Safety switch?
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
07-23-2019, 12:36 PM | #4 |
Does it crank?
Is not power to the distributor the only issue? Make sure your battery connections and grounds are clean and tight. Do your headlights work in each key position? Do they dim when you turn it to start? If they stay lit at the same (or similar) level, there is likely no power to the start position, and I would look at the ignition switch. If they go out, it seems like a large short. Either work your way backwards or forwards. Get a test light and the schematics, and work your way from one end to the other. I see NSS was suggested, but I believe NSS will interrupt the starter, but will still allow power to the ignition.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
08-02-2019, 12:44 PM | #5 |
Tried two brand new ignition switches, everything works fine lights, cluster still nothing when trying to start...fuel pump primes but when I turn to start absolutely nothing. I will try the neutral safety switch. Also have a new fuel pump. Talk about a pain in the @$$!
08-02-2019, 01:18 PM | #6 |
Tried to start in neutral same issue.
08-02-2019, 01:30 PM | #7 |
Do you know what the extra hot lead is off your choke fuse. I am always leery of funky wiring like that.
08-02-2019, 05:54 PM | #8 |
Yes, it's the external fuel pump.
08-03-2019, 01:28 PM | #9 |
It's weird because the neutral safety switch only have one connector plug with one green and one blue wire. Also the steering column has junkyard markings so there's no telling what year it's out of...the plug was almost unplugged so I put it back still nothing but I think it's just for reverse lights...just going to trace wires now.
08-03-2019, 03:05 PM | #10 |
Moderator
If the pump is working in RUN then it's not likely the problem.
Do you happen to know what year that fuse panel, and likely the cab harness, came from? The fuse panel layout doesn't seem to match the 1984 wiring diagrams. The Neutral safety switch simply interrupts the CRANK wire from the ignition switch to the starter. Despite my previous statement it's unlikely to be the power problem. I somehow misunderstood your post and thought it wasn't cranking. If she isn't cranking then look at this switch. Choke is powered by the Circuit 300 ORANGE wire off the ignition switch. Circuit 300 only has power in RUN not in CRANK. Bodge wires into fuse slots, like your fuel pump hookup, cause fires.Remove the bodge wire from the CHOKE fuse and repair the damage caused to the PAK CON terminals. Circuit 3 (PINK) from the ignition switch should stay powered in both RUN and CRANK. You're missing the IGN fuse... This fuse powers the points marked IGN on the 1984 fuse panel along with the HEI coil. Properly plug the fuel pump into an open Circuit 3 IGN slot on the fuse panel... NOT THE IGN FUSE SLOT. These spots in the fuse panel are either female PAK CON terminals, just like the fuse slots, that you can plug MALE 1/4 disconnect into or Male 1/4 disconnect terminals that you can plug a Female 1/4 disconnect onto. Incidentally. The Brake and some of the other warning lamps should light in CRANK. The ignition switch grounds Instrument Cluster Circuits 33 & 35 in that position only.
And please let us know if and how your repairs were successful. Last edited by hatzie; 08-05-2019 at 12:45 AM. |
08-05-2019, 07:26 AM | #11 |
This may be the problem. Maybe you check the dist. lead make sure it plugged in all the way or contacts is clean making good contact. Since you did change cap.
If this missed by mistake in hast truck will not turn over(fire). It happens to the best of us
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
08-05-2019, 12:38 PM | #12 | |
08-05-2019, 12:40 PM | #13 |
It's actually the wiring going to the starter solenoid. Really the whole harness is junky and that's being kind. Thanks for the advice!
08-05-2019, 01:00 PM | #14 |
Moderator
Your IGN fuse appears to be missing. That'll keep the HEI and anything else that supposed to be HOT in RUN & START/CRANK from getting any juice.
If you need the, usually PURPLE, SXL 14ga wire that runs from the bulkhead plug to the starter solenoid S stud... just make one. You'll need; A few feet of PURPLE 14ga SXL wire. #8 14-16ga ring terminal for the starter S stud. 14-16ga Packard 56 terminal. Unfortunately I've forgotten which gender. Match the gender of the terminal you're extracting. Two 2" sections of Adhesive lined heat-shrink for strain relief at the terminals. If the Circuit 2 RED wire(s) at the starter BAT terminal are chewed up just replace them as well. You'll need one or two 14ga fusible links on 3/8" ring terminals at the starter BAT stud and several feet of 12ga RED SXL wire with the correct terminals at the opposite end.
